running an oil restrictor....
Old Nov 26, 2006 | 03:59 PM
jrs2ksi's Avatar
Default running an oil restrictor....
I am putting together a turbo kit. I read some posts in here that say its a good idea to run an oil restrictor and that it will make ur turbo last longer. I was just wondering if it would be getting enough oil w/ one on there? thanks
Old Nov 26, 2006 | 04:05 PM
Dunc's Avatar
BCICAN
Default Re: running an oil restrictor.... (jrs2ksi)
Typically they say....
Non BB Turbos:
-3AN feed=don't really need one
-4AN feed=you should use one
BB Turbos need less oil than the above turbos. Basically look at what most have done and make an educated guess. Sometimes it works with no restrictor no matter the feed line. It's basically you're own call after you research what others have done.
Old Nov 26, 2006 | 04:08 PM
jrs2ksi's Avatar
Default Re: running an oil restrictor.... (AF-P Dunc)
thanks. How about u, u running one?
Old Nov 26, 2006 | 05:11 PM
platinum00's Avatar
A restrictor wont hurt anything and they are cheap. I would use one unless the turbo your getting has one built in.
platinum
Old Nov 26, 2006 | 06:06 PM
shortyz21's Avatar
Default Re: running an oil restrictor.... (platinum00)
run a -3 line and be done with it.
Old Nov 26, 2006 | 08:29 PM
mike93eh2's Avatar
my ball-bearing sc34 came with one..
Old Nov 26, 2006 | 09:22 PM
bigbadboy's Avatar
email some1 abt this very same question to use on my DBB GT35R and this was the response:
You have to determine if you even need a restrictor. Generally, the
restrictor is required if your engine runs very high oil pressures (e.g.
above 75 psi) and or idles high (over 45 psi). If this is the case, the
excess oil pressure can leak past the seals under certain operating
conditions.
You must know your oil pressures before and after adding the restrictor to
ensure you get enough oil to the turbo.
If you're unsure, don't do a restrictor. Worse case scenario is if you run
without one, find out you have an oil leak, you can always add one and the
problem goes away. No harm done. Most likely, you'll run without one and
never notice an issue.
Old Nov 26, 2006 | 09:32 PM
TheShodan's Avatar
Moderator
Default Re: (bigbadboy)
^^ Well-stated.
Old Nov 27, 2006 | 05:04 AM
inline4me's Avatar
I need an oil restrictor for my setup, where can I pick one up from. Also, what size is the restrictor hole typically?
Old Nov 27, 2006 | 05:19 AM
LSTEG96's Avatar
Default Re: (inline4me)
good thread... my 67 BB came with a restrictor already on the turbo, but many people have been telling me to run another restrictor from the back of the block... anyone know where i can find a solid answer on this? sorry to jack thread... it probably would have come up anyway...
Old Nov 27, 2006 | 07:12 AM
Dunc's Avatar
BCICAN
After a lot of debating with myself, I felt as though I should use one. I run a -4AN feed line and have pressures that get up to around 80-85psi during WOT.
Old Nov 27, 2006 | 07:25 AM
slambedcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AF-P Dunc &raquo;</TD></TR><TR><TD CLASS="quote">After a lot of debating with myself, I felt as though I should use one. I run a -4AN feed line and have pressures that get up to around 80-85psi during WOT. </TD></TR></TABLE>
as am i. actually around 90 psi. i think im just going to go with a -3AN line. that should solve any restriction needs.
Old Nov 27, 2006 | 07:28 AM
Topdawgg's Avatar
my GT35r has somethin that looks like a restrictor... im not sure if it is or not.. its brand new... do they come with them?
i have a -3an i believe and im seeing 75psi at WOT... 15 at idle...
Old Nov 27, 2006 | 01:06 PM
jrs2ksi's Avatar
Default Re: (Topdawgg)
thanks bigbadboy for the reply.
Old Nov 27, 2006 | 01:46 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inline4me &raquo;</TD></TR><TR><TD CLASS="quote">I need an oil restrictor for my setup, where can I pick one up from. Also, what size is the restrictor hole typically?</TD></TR></TABLE>
For the mid-framed turbos like the GT28RS up to the GT35R, you would use a .035" Restrictor. For the larger framed turbos it would be about .065"..
Old Nov 27, 2006 | 06:50 PM
inline4me's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
For the mid-framed turbos like the GT28RS up to the GT35R, you would use a .035" Restrictor. For the larger framed turbos it would be about .065"..</TD></TR></TABLE>
Thanks, this should fix my problem.
Old Dec 4, 2006 | 08:40 PM
cueballsi's Avatar
tracking
roachsboosted16
Oct 3, 2010 10:24 AM
JDM_Risa
Nov 22, 2005 08:28 PM
SpoolnByYou
Nov 20, 2005 07:04 AM
awdriscol4
Jul 10, 2005 10:06 AM
Dragline
Nov 13, 2004 06:00 PM
