whats this plug go to?
Old Nov 26, 2006 | 03:32 PM
NSfit's Avatar
Default whats this plug go to?
the wires are black and green>
Old Nov 26, 2006 | 03:43 PM
BlueIntegraBoy's Avatar
Default Re: whats this plug go to? (NScivic)
IACV?
Old Nov 26, 2006 | 03:55 PM
streettuned's Avatar
looks like cooolant temp or vtec.
Old Nov 26, 2006 | 03:59 PM
NSfit's Avatar
Default Re: whats this plug go to? (streettuned)
i cant be vtec because it came from a harness that dosnt have vtec. and my temp and IACV are already plugged in
Old Nov 26, 2006 | 07:33 PM
axtran's Avatar
evap purge, IAT, IAB, can be any of those
Old Nov 26, 2006 | 07:46 PM
LVB18Civic's Avatar
Default Re: (axtran)
I believe that the black and green wire connector is for power steering. It is the same connector as the IACV.
Old Nov 26, 2006 | 08:02 PM
Kamin's Avatar
Default Re: (LVB18Civic)
where is this plug in the engine bay? that would be nice to know lol
Old Nov 26, 2006 | 09:23 PM
NSfit's Avatar
Default Re: (Kamin)
its on the passenger side kinda by the thermostat, its from a CX harness so there is no power steering
Old Nov 26, 2006 | 09:58 PM
k20EP3's Avatar
Default Re: (NScivic)
it goes to a honda
Old Nov 26, 2006 | 10:01 PM
Minglor's Avatar
I believe black and green goes to the thermostat...
Old Nov 26, 2006 | 10:02 PM
fmrprojects's Avatar
Default Re: (k20EP3)
green and black is the fan switch sensor. its the switch right by the thermostat
Old Nov 27, 2006 | 08:31 AM
NSfit's Avatar
Default Re: (fmrprojects)
ok to clear thing up do you think someone can go and look and find out what colors their thermostat wires are
Old Nov 27, 2006 | 08:34 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Is your car throwing any codes/doing anything funny?
Old Nov 27, 2006 | 09:00 AM
NSfit's Avatar
Default Re: whats this plug go to? (Hatchy-Ownzjo0)
no the motor hasn't started yet i just finished the swap and trying figure out a few last problems
Old Nov 27, 2006 | 09:06 AM
miahmouse's Avatar
turn the ignition on and jump it (paperclip) if the fan comes on it's your fan switch... also, if there's a ground wire coming out right next to it then it's almost definitely your fan switch...
Old Nov 27, 2006 | 09:07 AM
NSfit's Avatar
Default Re: whats this plug go to? (miahmouse)
where does the fan switch plug into?
Old Nov 27, 2006 | 09:18 AM
miahmouse's Avatar
into the fan switch in the thermostat housing...
Old Nov 27, 2006 | 09:35 AM
NSfit's Avatar
http://www.hondaautomotivepart...1.gif
mine does not look like this.. it does not have the housing for this sensor. so if this plug just controls the fan can i just make a switch in that car to turn on the fan?
Old Nov 27, 2006 | 09:59 AM
sicones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse &raquo;</TD></TR><TR><TD CLASS="quote">turn the ignition on and jump it (paperclip) if the fan comes on it's your fan switch... also, if there's a ground wire coming out right next to it then it's almost definitely your fan switch...</TD></TR></TABLE>
And if your ECU lights on fire, then you know "how not to check where a plug goes"
Old Nov 27, 2006 | 10:26 AM
NSfit's Avatar
Default Re: whats this plug go to? (sicones)
yeah i know im not gonna do that
Old Nov 27, 2006 | 10:34 AM
if you using the 90-91 integra block then the fan switch is not gonna be on the therostat. just hook up a toggle switch to turn on the fan
Old Nov 27, 2006 | 10:37 AM
NSfit's Avatar
Default Re: whats this plug go to? (fmrprojects)
cool thanks thats what i was looking for..
Old Nov 28, 2006 | 05:04 AM
miahmouse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">And if your ECU lights on fire, then you know "how not to check where a plug goes" </TD></TR></TABLE>
You must have the worst luck in the world if you've actually managed to light an ecu on fire...
Old Nov 28, 2006 | 05:23 AM
cranny's Avatar
24.224.233.247
yeah would be on the back of the block i think , big rubber boot on it.
Old Nov 28, 2006 | 06:31 AM
sicones's Avatar
You must have the worst luck in the world if you've actually managed to light an ecu on fire...</TD></TR></TABLE>
Nope, I use a DMM.
