whats this plug go to?
Re: whats this plug go to? (streettuned)
i cant be vtec because it came from a harness that dosnt have vtec. and my temp and IACV are already plugged in
Re: whats this plug go to? (NScivic)
turn the ignition on and jump it (paperclip) if the fan comes on it's your fan switch... also, if there's a ground wire coming out right next to it then it's almost definitely your fan switch...
Re: whats this plug go to? (miahmouse)
http://www.hondaautomotivepart...1.gif
mine does not look like this.. it does not have the housing for this sensor. so if this plug just controls the fan can i just make a switch in that car to turn on the fan?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse »</TD></TR><TR><TD CLASS="quote">turn the ignition on and jump it (paperclip) if the fan comes on it's your fan switch... also, if there's a ground wire coming out right next to it then it's almost definitely your fan switch...</TD></TR></TABLE>
And if your ECU lights on fire, then you know "how not to check where a plug goes"
if you using the 90-91 integra block then the fan switch is not gonna be on the therostat. just hook up a toggle switch to turn on the fan
Re: whats this plug go to? (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">And if your ECU lights on fire, then you know "how not to check where a plug goes" </TD></TR></TABLE>
You must have the worst luck in the world if you've actually managed to light an ecu on fire...
You must have the worst luck in the world if you've actually managed to light an ecu on fire...</TD></TR></TABLE>
Nope, I use a DMM.
Nope, I use a DMM.
