tps wires
If you know how to use a multi-meter you can find it yourself. But the tps is the Throttle Position Sensor and it is mounted on the throttle body, are you with me? It has a tree wire connector connected to it and the sensor itself is black. If you need an explanation on how to determine ground and 12v wires let us know.
It is a 5volt sensor.
Ground will have continuity
With the key on and the engine off you should see 5 volts on one of the two remaining.
Last is the signal wire to ECU
giddyup21
Mar 18, 2012 06:49 PM
