wierd cel, help im about to loose my mind
Old May 9, 2002 | 09:38 AM
BoostedGSRBubble's Avatar
Default wierd cel, help im about to loose my mind
Ok, I get this cel on warm days over 70, and 4 out of 5 times I hae had a passenger. It comes on while driving and goes off when I turn the car off. The car doesnt go into limp mode b/c I still have vtec. But I cant check it because when I shut my car off, bridge the connector, and turn the ignition to acc, the cel is gone! Can i check it with the car running? Before I had a cel that would reset itself and it was a bad knock sensor, or a KS wiring problem. I checked my connections and coated them with 3m insulation, and I thought it was fixed. But that code would let me check it. Could it be like a loose wire which triggers the cel, but the connection is sufficent enough to fix itself. I dont have my ecu cover on so before I thought it was something with the passengers feet and the ecu, but the last time it came on there was no passenger. I didnt know a cel could reset itself w/o pulling the ecu fuse or battery cable. Any Ideas??
Old May 9, 2002 | 01:27 PM
spoon_ek9's Avatar
Default Re: wierd cel, help im about to loose my mind (trustsi)
check the code while the car is running.
Old May 9, 2002 | 01:32 PM
dohcsideSi's Avatar
Default Re: wierd cel, help im about to loose my mind (spoon_ek9)
it could be a misfire or fuel supply code which will reset itself when the car is turned off.
Old May 9, 2002 | 01:55 PM
spoon_ek9's Avatar
Default Re: wierd cel, help im about to loose my mind (dohcsideSi)
yea, should be some samll stuff. or else it wont reset it itself.
Old May 9, 2002 | 02:18 PM
TheIntegraGuy's Avatar
it cant be misfiring or fuel delivery...maybe a sensor is loose...Did you check your intake? maybe that's the case...
Old May 10, 2002 | 08:40 AM
Default Re: wierd cel, help im about to loose my mind (J-MiGiRL702)
Thanks all for your replies. So I can check the code while its runnin? Thats good to know. My intake is AEM CAI I will check everything connecting to it tonight, the problem is it only hapens every week or so, it's driving me nuts though. Any other ideas?
91ef_civic
Mar 22, 2011 02:33 PM
1sikhatch
Jan 31, 2010 09:06 AM
crazyguy
Aug 21, 2007 10:01 AM
slowpokecivic
10
Mar 9, 2006 02:23 PM
liquidxEG
Feb 22, 2005 03:46 PM
