how big to bore?
Old Nov 26, 2006 | 08:35 AM
CeeJayy's Avatar
Default how big to bore?
how big can you bore a b16a2 an is it even worth it?
Old Nov 26, 2006 | 08:49 AM
Luserkid's Avatar
Default Re: how big to bore? (CeeJay16)
As big as you want, but reliablity is another story and piston selection.
83mm is good for a build.
Old Nov 26, 2006 | 08:52 AM
hapexamendios 2.0's Avatar
R.I.P.
unless your doing most of the work yourself, it may be more worth your while to just buy an LS or GSR block
Old Nov 26, 2006 | 09:12 AM
CeeJayy's Avatar
Default Re: how big to bore? (honda 3300)
how big is 83mm? like a 1.8l
Old Nov 26, 2006 | 10:02 AM
Luserkid's Avatar
closer to 1.9.
Old Nov 26, 2006 | 10:58 AM
doood's Avatar
been there done that
Default Re: how big to bore? (Luserkid)
you can go all the way to 86mm if resleeved. but the sleeves are very thin at that point and you should only go this big if you're building a race only engine. 85mm would be the biggest you should go for a street car. stock sleeves you can go to 82mm.
Old Nov 26, 2006 | 11:01 AM
NJcoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">closer to 1.9. </TD></TR></TABLE>
Actually, a 83mm B16 has 1675.32cc's.
Old Nov 26, 2006 | 11:12 AM
Frozen E's Avatar
H-T White Ops
I went with an 84mm on my sleeved setup. Takes me to 1.73l
Old Nov 26, 2006 | 11:47 AM
goldhatch94's Avatar
just think of it as the bigger you go the thinner the walls go ,and the bigger the chance for crackeing stock sleaves
Old Dec 3, 2006 | 03:21 AM
RevTek 6's Avatar
Default Re: (goldhatch94)
better to get an ls or a gsr block. ls blocks are cheap.
Old Dec 3, 2006 | 04:25 AM
sauceja's Avatar
Default Re: (RevTek 6)
I found a mint gsr block for 600.00. Had to buy the whole longblock but selling the head and wire harness left me with a b18c1 block for 6 bills.
Also if not mistaken the b18c is still 81 mm the .2 difference is made up in rod/stroke and/or piston rod height.
Correct me if I am wrong on this as I don't stand behind that, it is just my understanding.
Then if you bored the 1.8 to a 84 mm I believe you would get around a 2.0L.
I haven't touched my 18c block yet as I am still learning tuning on my b16 and if I fry that I won't be hurt and have a fresh block on reserve.
philliedawg
12
Oct 18, 2007 10:26 AM
hondachris1994
Mar 24, 2006 04:21 AM
nickgmiller04
12
Mar 26, 2004 04:07 PM
blueturbo4door
Jul 29, 2003 08:51 PM
USDMMARK
Feb 9, 2003 01:58 AM
