Suspension & Brakes Theory, alignment, spring rates....
Tein spring change
Old Nov 26, 2006 | 07:08 AM
goldegg's Avatar
Default Tein spring change
I currently have a 92vx with Tein HA coilovers from a ITR and i belive they are 8/7 spring rates.
I would like to increase the spring rate since im running no sway bars.
Im thinking around a 10/9 setup over the 8/7.
the car handles very nice right now but i feel it would benifit from a slightly stiffer spring rate.
Does anyone know where i can get a new set of Tein or other good quality springs,
and does anyone have a suggestion for a good spring rate that is stiffer than the current 8/7
i like my car to handle very neutral with a slight taste of oversteer when needed at the limits, which is somewhat like it is right now.
Old Nov 27, 2006 | 06:44 AM
goldegg's Avatar
Default Re: Tein spring change (goldegg)
so nobody in the suspension forum knows good eg spring rates?
Old Nov 29, 2006 | 06:20 AM
goldegg's Avatar
bump
Old Nov 29, 2006 | 10:26 AM
.:Made in OC:.'s Avatar
get a comptech rear sway bar tie bar combo and high enough rates, the rear will whip out with ease.
Old Nov 29, 2006 | 11:45 AM
FalkenSiR's Avatar
Default Re: Tein spring change (Made In OC)
In theory, Ground control Custom rates could be your solution. But I wouldn't know if they are the same diameter or if they would even fit into the tein shock body.
Old Nov 29, 2006 | 02:00 PM
nonsense's Avatar
I'd keep the rates where they are and get a rear sway bar. I'm running essentially the same rates (450/400) and with he rear ITR bar the rear will step out at will
Old Dec 3, 2006 | 04:45 PM
k20EP3's Avatar
Default Re: Tein spring change (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">I'd keep the rates where they are and get a rear sway bar. I'm running essentially the same rates (450/400) and with he rear ITR bar the rear will step out at will </TD></TR></TABLE>
I agree 100%
Old Dec 4, 2006 | 12:31 AM
archmage's Avatar
To change out the Tein's:
What spring options do we have? Do we have to use tein's springs, or will others fit?
I'm looking to decrease my front spring rate as I feel it's overly stiff for the street - and I've been wanting to do this for a while now... I think it's about 750f/550r right now, I was just going to swap it down to about 550/550 all around, and run a bigger rear-sway.
Old Dec 4, 2006 | 09:48 AM
mike-y's Avatar
Default Re: Tein spring change (archmage)
when I had the tein flex, the spring inner diameter was ~2.75". Most aftermarket springs, like the ERS that GC sells are 2.5" ID, so they wouldn't fit, which sucked, because that size spring is hard to find on the used market. So you pretty much have to order new ones from Tein, unless you get really lucky.
I'm not sure if the HA's use the same size spring though.
Old Dec 4, 2006 | 12:41 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: Tein spring change (mike-y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-y &raquo;</TD></TR><TR><TD CLASS="quote">when I had the tein flex, the spring inner diameter was ~2.75". Most aftermarket springs, like the ERS that GC sells are 2.5" ID, so they wouldn't fit, which sucked, because that size spring is hard to find on the used market.
Yup. Plus you are stuck with their springs and lack of rates available. 2.5" ID should just be universal
eluam
Oct 20, 2008 08:11 AM
De_tour
Feb 4, 2008 06:17 AM
BOTAN01
Jan 23, 2008 05:46 PM
i0o0ll0o0i
Suspension & Brakes
May 9, 2006 05:55 PM
deviant1
Mar 26, 2004 03:42 PM
