what Should i Run N/a or Turbo Charge?? on a 96 LS and Which Setup is good on it??
i wanna know what setup i should run..N/a or TurboCharge?
and what setup is bettr??? and what should i get ( i mean the parts ) is better
That's something that you need to decide on your own. It depends on what your power goals are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJNauTicz »</TD></TR><TR><TD CLASS="quote">how much of a HP diffent?</TD></TR></TABLE>
It really depends on the setup and budget. There are so many options with NA and FI. Im guessing your going to stick with your B series. If so then anything over 240whp I would go FI.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER »</TD></TR><TR><TD CLASS="quote">turbo=straight line
NA=turns</TD></TR></TABLE>
Not necessarily. There are quite a few guys in the RR/Auto-X forum that are turbo'd and do quite well. It all depends on the setup.
Ali
Modified by PrinceAli132 at 10:04 AM 12/28/2006
Ali
FI?? hmm..i was thinkin..should i run turbo or..n/a i'm stil thinkin...but what i can do to make the Hp boost.for N/a ??
wat part's i should get and done..do you know any info?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJNauTicz »</TD></TR><TR><TD CLASS="quote">FI?? </TD></TR></TABLE>
FI = Forced Induction, a.k.a. Boost, Turbo, ect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJNauTicz »</TD></TR><TR><TD CLASS="quote">but what i can do to make the Hp boost.for N/a ??</TD></TR></TABLE>
Not exactly sure what your asking. Are you trying to ask what can be done to increase whp through NA?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJNauTicz »</TD></TR><TR><TD CLASS="quote">do you know any info?</TD></TR></TABLE>
There is tons of info on this site which can be acquired through searching, but don't forget to include archived content when searching.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJNauTicz »</TD></TR><TR><TD CLASS="quote">wat part's i should get and done</TD></TR></TABLE>
It depends on your budget and goals for the car. Don't spend money on crap that your going to regret later and having to spend more money to change out later. Also if you end up going FI/turbo then quite a few of your NA parts will become useless.
You have to figure out what you want to do with the car first.
Edit - Also, a good place to start is with making sure your car is up to date with all maintenance and is in good running order. Then you can work on your brakes, suspension and tires, which will be beneficial no matter what route you take.
Ali
Ali
Edit - I am a retard, I obviously don't read titles.
Ali
Modified by PrinceAli132 at 1:16 PM 11/26/2006
Modified by PrinceAli132 at 1:17 PM 11/26/2006
Ali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 »</TD></TR><TR><TD CLASS="quote">
How can you make a recommendation? We don't know what route he wants to take. Ali</TD></TR></TABLE>
wat part's i should get and done..do you know any info?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 »</TD></TR><TR><TD CLASS="quote">And most importantly we don't even know what motor he has (atleast I don't).</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJNauTicz »</TD></TR><TR><TD CLASS="quote">on a 96 LS and Which Setup is good on it??</TD></TR></TABLE>
