Anyone has pics of del sol dohc shift linkage and 99-00 Si for comparison?
Old Nov 26, 2006 | 06:10 AM
civic2slo's Avatar
Default Anyone has pics of del sol dohc shift linkage and 99-00 Si for comparison?
Anyone has pics of a del sol dohc shift linkage and 99-00 Si for comparison?
Old Nov 26, 2006 | 10:30 AM
BlueIntegraBoy's Avatar
Default Re: Anyone has pics of del sol dohc shift linkage and 99-00 Si for comparison? (civic2slo)
GSR and Si shift linkages are the same
Old Nov 26, 2006 | 04:18 PM
streettuned's Avatar
Default Re: Anyone has pics of del sol dohc shift linkage and 99-00 Si for comparison? (BlueIntegraBoy)
the del sol is longer, you could just cut them in half, install them hold the shifter in center, add metal in between, weld and then paint. when I did my b16 the linkage i had was from a delsol, i had to cut the linkage.
Old Nov 26, 2006 | 04:43 PM
Suck my DX's Avatar
the dohc del sol linkage is way long...i had to cut a little over two inches off of it to swap a b series in my buddies eg hatch
Old Nov 26, 2006 | 08:58 PM
midnitesol's Avatar
Default Re: (Suck my DX)
so you just cut, measure, and reweld and it should be good? im going to be swapping my gsr from my del sol to my eg and i hadn't heard of this before so any info would help. thanks ahead of time.
Old Nov 26, 2006 | 09:07 PM
Suck my DX's Avatar
Default Re: (midnitesol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnitesol &raquo;</TD></TR><TR><TD CLASS="quote">so you just cut, measure, and reweld and it should be good? im going to be swapping my gsr from my del sol to my eg and i hadn't heard of this before so any info would help. thanks ahead of time.</TD></TR></TABLE>
pretty much...i cant remember if i had to cut both pieces or not...either way it shouldnt be too difficult...just make sure that the shifter sits straight in the cabin before you reweld it...lol the first time i made one it came out with a mean gangster lean...hahaha
as far as shortening it, remove the material from the straight portion of the linkage...you dont need to be super exact with the length...there is about 2 inches of adjustability, but its always good to double check before you weld...hope that helps some
Old Nov 26, 2006 | 09:18 PM
midnitesol's Avatar
Lol, cool thanks i would have definitely been stuck when doing this.
Old Nov 26, 2006 | 09:42 PM
Suck my DX's Avatar
no prob...im in socal too....pasadena to be exact....hit me up if you run into any problems...later
secularhonda
12
Mar 17, 2014 11:22 PM
powerline707
Jun 16, 2011 01:41 PM
b18c1del
Mar 29, 2008 12:54 AM
skiracer8148
Mar 17, 2007 05:09 PM
jd_bh03
Jul 14, 2004 02:15 PM
