misfiring in every cyl.
Old Nov 25, 2006 | 07:15 PM
ridin98civic's Avatar
Default misfiring in every cyl.
i am getting a misfire code on all four cylinders. the car is a 98 ej8. plugs and wires are ngk and under a year old, and just replaced the factory coil. 02 sensor is about a month old. the car has approx. 140,000 miles on it. what could it possibly be, or is it just that i have a stage 2 crower cam?
Old Nov 25, 2006 | 07:27 PM
Blk00EJ8's Avatar
Default Re: misfiring in every cyl. (ridin98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">i am getting a misfire code on all four cylinders. the car is a 98 ej8. plugs and wires are ngk and under a year old, and just replaced the factory coil. </TD></TR></TABLE>
When you changed your factory coil, did you unplug your plug wires from your dizzy cap? And if so, did you make sure you put them back on in the proper order so they would be firing correctly?
Cylinder 1 on your left... cylinder 4 on your right
looking at the dizzy from passenger side:
4 2
3 1
Old Nov 25, 2006 | 08:03 PM
Default Re: misfiring in every cyl. (EKcivicEX)
yes i did, it most likely wouldnt even run if that was the case. it runs fine the CEL just comes on. and i have reset the ECU since installing the coil. the coil was an attempt at fixing this misfire problem. anything else?
Old Nov 26, 2006 | 01:39 PM
bump
Old Nov 26, 2006 | 03:25 PM
jdeemseerx's Avatar
you pretty much answered your own question.. do you have an aftermarket cam gear? what is your cam timing at? Ignition timing? My guess is after your tuned your CEL will go away
Old Nov 26, 2006 | 03:54 PM
streettuned's Avatar
is your firing order correct? it may be off.
Old Nov 26, 2006 | 06:28 PM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">yes i did, it most likely wouldnt even run if that was the case. it runs fine the CEL just comes on. and i have reset the ECU since installing the coil. the coil was an attempt at fixing this misfire problem. anything else?</TD></TR></TABLE>
I agree that it may not even run but if 2 cylinders were correctly wired and 2 were swapped, 2 functional cylinders would be enough to keep the engine going but you would be able to hear it distinctly. You said a CEL on all 4 cylinders so rule that out.
It's highly possible that your timing is just off. An aggressive aftermarket cam could make for a rough idle, but shouldn't cause misfire CELs to be thrown.
When did you start seeing the CELs and was there any coincidence with anything just installed?
Old Nov 26, 2006 | 09:06 PM
starting getting one for just cyl 3 shortly after having the cam installed. i have no aftermarket gear and crower said that at stock timing the cam would be correct. i have replaced the plugs and wires within the past year and the new coil a week ago. the only things coinciding with the CEL would be a header (which is no longer on my car, got a new one) and the cam. maybe timing got messed up somehow? would that cause this?
Old Nov 26, 2006 | 09:16 PM
jdeemseerx's Avatar
indeed it would.. if you have a timing light or have access to one, reset your ignition timing and the ecu
Old Nov 26, 2006 | 09:21 PM
Default Re: (jdeemseerx)
i do in fact have access to one. could i try and correct it by advancing/retarding the dizzy? or would it be best to take it off and put it back on with cyl one at top dead center or whatever it is.
Old Nov 26, 2006 | 10:11 PM
jdeemseerx's Avatar
it doesnt matter, im not sure if you know this but you correct ignition timing by turning the dizzy while the engine is running and at operating temp.
Old Nov 26, 2006 | 10:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt matter, im not sure if you know this but you correct ignition timing by turning the dizzy while the engine is running and at operating temp. </TD></TR></TABLE>
knew that but didnt know to what degree i could advance/retard
Old Nov 26, 2006 | 10:23 PM
krazyhmongboi's Avatar
how do u reset ignition timing? im mis firing on all cylinders also..
Old Nov 26, 2006 | 10:26 PM
Default Re: (krazyhmongboi)
you would use a timing light to properly "set" the timing and then would need to "reset" the ecu by either pulling the fuses for a few minutes or disconnecting ground for a few minutes(better have your radio stations memorized, lol)
Old Nov 27, 2006 | 06:30 AM
Blk00EJ8's Avatar
Default Re: (ridin98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">starting getting one for just cyl 3 shortly after having the cam installed. i have no aftermarket gear and crower said that at stock timing the cam would be correct. i have replaced the plugs and wires within the past year and the new coil a week ago. the only things coinciding with the CEL would be a header (which is no longer on my car, got a new one) and the cam. maybe timing got messed up somehow? would that cause this?</TD></TR></TABLE>
It's highly possible that when the cam was installed your timing belt was put back onto the cam gear lined up on the wrong teeth, so that would account for incorrect timing. Was timing checked after the install?
Old Nov 27, 2006 | 11:43 AM
Default Re: (EKcivicEX)
when the cam was installed the cam, timing belt, water pump were all changed so im assuming it was, but never checked myself.
Old Nov 29, 2006 | 04:05 AM
Blk00EJ8's Avatar
Double check that to be sure.
Old Nov 29, 2006 | 08:18 AM
thanks for all the help, funny thing is the CEL went away now, i dont know what is goin on, but i will check the timing
Old Nov 29, 2006 | 08:40 AM
Sloshy's Avatar
did you change or clean the distributor cap, carbon tracking can be your problem
Old Nov 29, 2006 | 02:55 PM
Default Re: (hatch-E-vanish)
i checked all the contact points and the rotor when changing the coil and they all appeared as clean as a hospital floor
Old Nov 29, 2006 | 03:09 PM
cranny's Avatar
24.224.233.247
your exhaust valves might be too tight dude. have a look at them.
Old Nov 29, 2006 | 03:12 PM
Default Re: (cranny)
thanks yea theres a few things i need to check evidently
seifer
Apr 22, 2005 04:46 PM
sk8
Nov 17, 2004 02:54 PM
EK_vzla
Aug 30, 2004 01:39 PM
Kyle244R948
Aug 5, 2004 02:39 PM
apexiintegra
Aug 23, 2003 04:28 PM
