Oil in Brake master cyclinder causes brake light to come on?
Old Nov 25, 2006 | 02:13 PM
R-81 Coupe's Avatar
Default Oil in Brake master cyclinder causes brake light to come on?
My brake light is on and I realize that somone filled up my brake master cylinder w/ oil. Is that causing the brake light to come on? Is it even safe? Can i remove the oil or i need to replace the brake master cylinder?
thanks.
Old Nov 25, 2006 | 02:20 PM
pdiggitydogg's Avatar
how do you know its oil?
clean oil and brake fluid can look very similar
The brake light is pretty dumb - if the float in the mc falls, the light comes on; if the ebrake is up, the light comes on.
The float wouldnt know the difference between oil and brake fluid.
Old Nov 25, 2006 | 02:28 PM
BlueIntegraBoy's Avatar
Default Re: Oil in Brake master cyclinder causes brake light to come on? (R-81 Coupe)
Yes, you can remove the oil by flushing your system with brake fluid. Don't know if the oil will affect any of the seals in the calipers.
R-81 Coupe's Avatar
Default Re: (pdiggitydogg)
It smells like oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you can remove the oil by flushing your system with brake fluid. Don't know if the oil will affect any of the seals in the calipers.</TD></TR></TABLE>
If I flush it out will my brake light go off?
Old Nov 25, 2006 | 02:30 PM
Default Re: (R-81 Coupe)
Oil is slimier (viscous) than brake fluid
Old Nov 25, 2006 | 02:39 PM
guess it depends on the fluid and oil you use
either way, like i said, the light isnt that smart
if the float...floats...the light will go off (assuming the electrical is sound)
If you think its oil, just flush it...
Old Nov 25, 2006 | 02:44 PM
R-81 Coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">guess it depends on the fluid and oil you use
If you think its oil, just flush it...</TD></TR></TABLE>
so the float isn't floating, that's why my light is on?
Old Nov 25, 2006 | 02:47 PM
maybe...
Go out, turn the car on, pull the mc cap, push the cap's float up manually and see if the light goes off.
if it doesnt turn off, its something else (check your ebrake electrical connector next)
cranny's Avatar
24.224.233.247
Default Re: (BlueIntegraBoy)
not designed to be compressed though. bleed a back wheel till you get brake fluid out of it. than do the other 3 wheels. shouldnt hurt nothing , if you get it out.
Old Nov 25, 2006 | 03:27 PM
jdeemseerx's Avatar
if it is infact oil.. thats gonna be alooottt of bleeding good luck i hope you didnt pay for a service and the douche put oil in your MC.. if so i would go back and raise hell how exactly did that happen anyway im curious?
Old Nov 27, 2006 | 10:02 AM
bluebeast's Avatar
Default Re: (jdeemseerx)
IS THE FLUID BLACK?Cud mean the seals in ur mc are toast.still wudnt make the light *** on,wat model is your car?
adamcm16
Apr 10, 2014 05:07 PM
zenon8890
24
Jun 24, 2007 02:58 PM
93preludeh22
Dec 1, 2006 05:27 PM
ek9junky
Jun 15, 2006 11:00 PM
return_2020
Apr 19, 2005 12:31 PM
