More blinker nightmares =<
When i first got my del sol the blinkers didnt work. After swapping in and out a billion and one parts we figured out the flasher was blown, $95 later my right turn signal works and my left turn signal operates the hazards and my hazard switch does nothing? The wiring is stock which is even more confusing
lol, sound like someone took off their steering column cover and put it on wrong. jiggle around that plastic and see if it makes a difference. mine did that before. also... check to see if ur hazard switch is working. pull one from the junkyard. if ur hazard doesn't work.. ur blinkers won't work properly.
Champ White EJ8
12
Mar 1, 2005 09:43 PM
