Rear seat removal and fuel sending unit help needed
Old Nov 25, 2006 | 09:33 AM
howard515's Avatar
Default Rear seat removal and fuel sending unit help needed
My fuel gauge is not working properly in my 1994 Accord. I believe its my fuel sending unit. Can someone tell my how to remove the rear seat. I believe that is were the sending can be access.
Old Nov 25, 2006 | 09:42 AM
hondadude's Avatar
Default Re: Rear seat removal and fuel sending unit help needed (howard515)
I would look behind the rear seat on the passenger side for a round cover plate.
But, to answer your question. The rear seat has a 10mm bolt about the center of the seat where the back and seat bottom meet, you'll have to cram your fingers in the crack to find it, then use a socket and extension to get the bolt out. Then you fold the seat foward and it has wire hooks that fit in slots at the front. Now you can grab up all the loose change people have lost over the years.
Old Nov 25, 2006 | 10:59 AM
howard515's Avatar
Default Re: Rear seat removal and fuel sending unit help needed (hondadude)
Hondadude--Thanks for the help. I got the rear seat out (bottom cushion) but did not see the round plate. Is the sending unit in the trunk or behind the back cushion????
Old Nov 25, 2006 | 12:16 PM
khunt0012's Avatar
Meat Robot Invisible
You should be able to see it once the bottom part of the seat is out. It'll be a circular plate that's a different color then the cars color. You physically have to take it apart to be able to get into the tank.
Old Nov 25, 2006 | 01:02 PM
The-Kid's Avatar
last time I checked on my parents 01 Accord(it should be the same) take out the whole cover in the trunk. The one that is covering the spare tire. There should be 1 screw or clip holding it down to the trunk floor. You'll see it.
Old Nov 26, 2006 | 03:22 AM
Duane_in_Japan's Avatar
Default Re: (The-Kid)
I vote for in the trunk. If the cover plate has that black sticky gum holding it down along with some hardware, DO NOT get gas on the gum and then let it drip into the tank, the whole tank will be colored black then traces of gum will get in your pump sock and your fuel filter. Put some plastic wrap on the gum before you remove the float unit. If no gum, then NEVER MIND.
Old Nov 26, 2006 | 04:53 AM
BLKFLSH's Avatar
Here's a link where Honda-Pro explains how to test the wires. Good luck
https://honda-tech.com/zerothread?id=1588309
Old Nov 26, 2006 | 08:40 AM
YeuEmMaiMai's Avatar
94-97 fuel sender is under rear seat 98+ in the trunk
If so, I beleive that you can replace th sender without dropping the tank but if your fuel pump is out, then you gotta drop the tank...
Old Jun 2, 2007 | 09:22 AM
94accordlxf22b2's Avatar
my haynes manual says the access panel to the feul sending unit is under rear seat and so does alot of threads i've read online but having just done it 10 min ago i can tell you that on my 94 accord lx a/t 2dr cd7 f22b2 that it is in the trunk close to the back seat but having removed the back seat 1st, it's definatley not under there.
sageuvagony
Dec 25, 2008 12:54 PM
DB8_TEG
May 26, 2003 08:29 AM
JerryJ
Feb 2, 2003 06:33 AM
CivicExPimp
May 9, 2002 09:08 PM
MRDC2
Aug 19, 2001 04:01 PM
