How to do H22a4 timing??
i need help on doing the timing for my fifth gen.....ive heard that the ecu does it by itself...but mechanics say there is a way to do the timing...so i need to know...and if there is a way can someone give me steps...thanks your help is appreciated.
well i was just wondering is there any special timing i should know about???the distributor isnt moviable i know that so timing on the ignition isnt possible but do the cams and flywheel have to be timed??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_lude »</TD></TR><TR><TD CLASS="quote">well i was just wondering is there any special timing i should know about???the distributor isnt moviable i know that so timing on the ignition isnt possible but do the cams and flywheel have to be timed??</TD></TR></TABLE>
dont those have timing marks?
You could adjust base timing by converting to OBD I and replacing your distributor or drilling adjustable hole.
That's if you mean ignition timing, for the cams you would need adjustable cam gears.
People have been tring to tell you. The only thing on an A4 you can mess with is the cam/crank timing by adjustable cam gears and how you set the timing belt. Of course there is only 1 right way to have the timing belt set...
If you TB is off, you car will not run right and you will know it.
What are you trying to do?
my throttle response has been real bad and mostly when i shift in third from 2-3000rpms the car jerks as it is loosing a little bit of power..
OK, so your timing belt is probably off a tooth or so. Just check the marks on the cam gears with the timing marks on the flywheel.
Get a manual to give you all the details.
So wait...timing on the a4 can only be done through the cam and the flywheel...last time i checked on the flywheel it seemed off...it ran at 12-17 saying it was good through it....but i think there was something wrong...is there??
if you are checking the timing properly
- engine at operating temp
- service connector jumped
the timing mark should line up with the timing teeth in the tranny housing. if they don't then you need a new ignition control module for the dizzy.
oy, sorry about the slang. the service connector is under you dash. behind that removable piece on the passenger side. little blue thing w/ a 2 pic connection. stick a paper clip in there to jump the connector. dizzy = distributor. your ignition control module is inside the dizzy(distributor).
you are best off getting a new, or working used distributor. not alot of people take the ICM out. good luck, im sure you can get one from someone pretty cheap on here. its too bad, cuz i have a dizzy sitting right here, but ALL the screws inside are fused so i couldnt take it apart to rebuild it.
I'm having the same problem with not being able to adjust the timing with the dizzy..what is the purpose of the service connector being jumped for adjusting the timing?
It puts the ecu into open loop so it not trying to adjust timing off the stock map. You're supposed to do the same thing when adjusting idle and a few other things.
Ignition timing is done solely by the ecu in OBD2; no adjustments in the dizzy.
Nice, so is there a step by step on how to do this or do I just plug the jumper wire in then turn the car on and let the ecu do it's magic?
i don't think you are understanding. even if you move the distributor the ecu is automatically going to try to re-adjust your timing back to the factory setting. If you want to adjust your timing to something other than factory spec you are going to have to change your ecu. what they were talking about earlier is how to check to make sure the factory setting is correct and you don't have something causing the timing to be off such as a bad ignition control module (ignitor) in your dizzy.
Sounds like you may have skipped a tooth when installing the belts? Or somethings probable wrong with your balancer shaft assemble. Take it to a Honda dealer and talk to one of the service tech guys and see if he cant give some direction. Some of those guys do know what their talking about....sometimes...lol. I get advice from my service techs all the time. Helps me out quit a bit. Good luck with this and hope all works out for ya.
