ls/vtec dowel pin drill bit size
Old Nov 24, 2006 | 10:14 PM
teamvirus's Avatar
My car breaks a lot!
Default ls/vtec dowel pin drill bit size
im going cheap and going to drill my head for the ls/vtec.....but not sure what size bit to use.....did a search and found nothing
Old Nov 24, 2006 | 10:19 PM
teamvirus's Avatar
Default Re: ls/vtec dowel pin drill bit size (teamvirus)
is it 9/16?
Old Nov 25, 2006 | 12:52 AM
teamvirus's Avatar
bump
Old Nov 25, 2006 | 02:22 AM
teamvirus's Avatar
ttt
Old Nov 25, 2006 | 02:27 AM
turbod da's Avatar
they sell the dowel pins for lsvtec so u wont drill ur head 4 about 20bucks i have them my sell on my car. call thomas at camp1320 1 {818}718-9352 just trying to make it easier 4 you!
Old Nov 25, 2006 | 02:31 AM
teamvirus's Avatar
Default Re: ls/vtec dowel pin drill bit size (SNACH)
ya but i need to finish the swap tomarrow...so i need to drill cause i dont have time to buy
Old Nov 25, 2006 | 02:33 AM
turbod da's Avatar
i believe its a metric but my friend got away with a 9/16. so yes.
Old Nov 25, 2006 | 03:52 AM
teamvirus's Avatar
anyone know the metric bit size??
ps thanks
Old Nov 25, 2006 | 09:41 AM
nub's Avatar
nub
14mm
Old Nov 25, 2006 | 03:36 PM
thehondaconnection's Avatar
Default Re: ls/vtec dowel pin drill bit size (nub)
do not use a 9/16 or your head will most likely leak due to it being to big and the head will be able to wiggle.only use the 14 mm or the special dowels.
Old Nov 25, 2006 | 03:42 PM
over_'s Avatar
measure the dowls???
Old Nov 25, 2006 | 03:48 PM
Padawan's Avatar
Darth ModerVader
This is really something that should be done with more precision than using a hand drill in someone's garage. A press should be used if they're going to be drilled.
slowesteg
Apr 20, 2011 11:59 AM
Jay J
19
Feb 3, 2005 01:12 PM
infamousALLMTR
Jan 7, 2003 09:48 AM
