ls/vtec dowel pin drill bit size
My car breaks a lot!
im going cheap and going to drill my head for the ls/vtec.....but not sure what size bit to use.....did a search and found nothing
Re: ls/vtec dowel pin drill bit size (teamvirus)
they sell the dowel pins for lsvtec so u wont drill ur head 4 about 20bucks i have them my sell on my car. call thomas at camp1320 1 {818}718-9352 just trying to make it easier 4 you!
Re: ls/vtec dowel pin drill bit size (SNACH)
ya but i need to finish the swap tomarrow...so i need to drill cause i dont have time to buy
Re: ls/vtec dowel pin drill bit size (nub)
do not use a 9/16 or your head will most likely leak due to it being to big and the head will be able to wiggle.only use the 14 mm or the special dowels.
Darth ModerVader
This is really something that should be done with more precision than using a hand drill in someone's garage. A press should be used if they're going to be drilled.
Jay J
19
02-03-2005 01:12 PM
