95 GS-R w/turbo - half-core radiator & fan options
I'm looking to replace my manifold and turbo, and want to convert to a half-size radiator and fan combo that will work in my '95 Integra GS-R.
Obviously these are not "direct replacement" parts. Can anyone in the know let me know which parts will work, and where to order them? I'll need the radiator, mounting hardware, an appropriate fan, and hoses.
Thanks!
- TAZ
Thanks!
- TAZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TerryZ »</TD></TR><TR><TD CLASS="quote">I'm looking to replace my manifold and turbo, and want to convert to a half-size radiator and fan combo that will work in my '95 Integra GS-R.
Thanks!
- TAZ</TD></TR></TABLE>
PM Bob @ http://www.rcautoworks.com
I've got the half size radiator and fan insalled on my turbo setup. He'll give you a discount if you buy both. Tell him tweekerz sent you.
Thanks!
What happens to the stock overflow tank if using the offset Civic-style radiator? Is it eliminated? If not, is the repositioned/remounted somewhere?
Is the Fluidyne part number for the '92-'00 Civic (FHP11-92CIV) the proper one for this application?
Lastly, do the original upper and lower hoses fit, or is it necessary to change them?
Stock Del Sol Rad
14" universal Hayden fan setup as a pusher
oem gsr rad bracket
For the hoses you can most likely just use your stock teg hoses. With my H22 the requirements were different.
oem gsr rad bracket
TenaciousC
Aug 8, 2002 07:21 PM
