B16 builds in the 12-14 second 1/4 mile times
Old Nov 24, 2006 | 07:24 PM
allnaturalb16's Avatar
Default B16 builds in the 12-14 second 1/4 mile times
Any B16 enthusiast knows that it was one of the originators of this honda craze today.
Anyone on honda tech and I...would like to know about you b16 builders out there that are dipping into the low numbers on the quarter mile.
Whats your setup? How fast? What chassis? Tranny? Dyno #'s? b16 builders stand up.....
Old Nov 24, 2006 | 11:05 PM
zap's Avatar
zap
Default Re: B16 builds in the 12-14 second 1/4 mile times (allnaturalb16)
Here's mine, b16a stock bore stock stroke. EF hatch full interior, 15" street tires.
https://honda-tech.com/zerothread?id=1756316
Old Nov 25, 2006 | 06:02 AM
nsxmatt's Avatar
Not really a "built" motor but my old B16 setup in a 92 Civic VX.
Stock JDM B16
AEM CAI
DC 4-1
Greddy SP w/no cat
Skunk 2 chipped p28
Ran 13.9@98mph on DR's
Old Nov 25, 2006 | 06:33 AM
CBURKE's Avatar
I'm in for this one, I have a CRX with a B16A that I am building. This will help me in what I am looking ay doing.
Old Nov 25, 2006 | 10:11 PM
Default Re: (CBURKE)
good stuff keep it coming......
my motor almost broken in cant wait
hoping for a low 14 maybe 13 in my CRX
b16s need to represent...these bigger disp. builder say we dont have torque but lets show em some numbers and most of all the ability to rev high (the fun part)
Old Nov 26, 2006 | 01:29 PM
A1's Avatar
A1
Default Re: (allnaturalb16)
88 crx
stock non-obd block (never been touch)
00 si head (mild port)
blox cams
blox spring
blox IM
jg header(modified collector to 2 1/2)
aem cam gears
best time 13.08 @ 105 mph on slicks
Old Nov 26, 2006 | 01:45 PM
D.LandaPerformance's Avatar
Default Re: (d16why8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16why8 &raquo;</TD></TR><TR><TD CLASS="quote">88 crx
blox cams
blox spring
blox IM
aem cam gears
best time 13.08 @ 105 mph on slicks </TD></TR></TABLE>
Thats some good mph Should be able to get to a 12.7-12.8 with better 60ft.Whats the weight of the car?
Old Nov 26, 2006 | 03:10 PM
mar778c's Avatar
Community Builder
Community Influencer
blox cams
blox spring
blox IM
aem cam gears
That is an impressive time for that set-up.
Old Nov 26, 2006 | 08:28 PM
zap's Avatar
zap
I agree. That's a very fast trap speed
Old Nov 27, 2006 | 03:02 PM
Default Re: (zap)
See what i mean....b16s can really fly.
Been lovin em since i could drive. And the CRX is the perfect candidate for the motor. Too much torque and your just spinning em off the line...
Great times on the 1/4 mile!! D16why8
Old Nov 27, 2006 | 03:13 PM
xDicktonesx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 &raquo;</TD></TR><TR><TD CLASS="quote"> Too much torque
no such thing.
just put a buddy's car together.
xsi integra block
p30 pistons
2 layer HG
blox B cams
BC flat faced valves
omni springs and retainers
stock p30 manifold
gsr tb
jdm itr 2.5'' header
2.5'' exhaust
phearable ecu 4100 luanch control, full throttle upshift, 9100 rpm rev limit
00 si tranny
most fucked up wiring harness i have ever layed eyes on.
once we raise the rev limit up to where it should be which is 9600rpms or so this thing should turn mid 13s in a 2050lb 92 eg cx. driver is like 130 lbs soaking wet.
sounds like a lot of goodies but we just thru this thing together in one weekend from **** layin in the garage.
Old Nov 27, 2006 | 03:16 PM
FaceTuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 &raquo;</TD></TR><TR><TD CLASS="quote">See what i mean....b16s can really fly.
Great times on the 1/4 mile!! D16why8</TD></TR></TABLE>
the only reason b16's actually move is cause the tranny i bet you times would be alot different with an ls trans.
Old Nov 27, 2006 | 03:34 PM
B18C1_POWER's Avatar
Default Re: (FaceTuned)
87 crx, full interior, b16a - 81mm pct pistons-skunk-2 cams, stock head-I/M- T/B- and injectors, pr3 ecu - dc header- 2.5 exhaust with magnaflow muffler, custom intake, 13.7-103 with 2.3 60's ft with 15 nitto drags, reviing it to 8500, have some electrical problems don't let me rev it more ,
Old Nov 27, 2006 | 04:12 PM
Default Re: (B18C1_POWER)
put a more built b18c1 in a crx than what you are talking about and try to launch as hard a b16 with the same tires and you wont launch as good.....too much torque all motor for crx is possible but if you really have the right setup and know how to drive you will yield better times.....
and about the LS trans....why would you ever want an LS trans on a b16 to begin with or any all motor app goin 1/4 mile?
Old Nov 27, 2006 | 04:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 &raquo;</TD></TR><TR><TD CLASS="quote">put a more built b18c1 in a crx than what you are talking about and try to launch as hard a b16 with the same tires and you wont launch as good.....too much torque all motor for crx is possible but if you really have the right setup and know how to drive you will yield better times.....
are you seriously trying to tell people that MORE TORQUE means a potentially slower car because you "wont launch as good?
no. i thought you might be halfway intelligent until i heard that.
youll notice that the few fast b16s out there are the ones that make more than 118wtq or so.
i dont get people that say "right set up and good driver and youll go fast" does that just sound good when you read it back to yourself? as if you know what your talking about? wow....good thread
Modified by xDEFTONESx at 6:38 PM 11/27/2006
Old Nov 27, 2006 | 05:21 PM
crx=si's Avatar
here's my build:
fastest time to date 11.46@ 118mph
https://honda-tech.com/zerothread/1780228
Old Nov 27, 2006 | 05:42 PM
Default Re: B16 builds in the 12-14 second 1/4 mile times (crx=si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx=si &raquo;</TD></TR><TR><TD CLASS="quote">here's my build:
https://honda-tech.com/zerothread/1780228 </TD></TR></TABLE>
just because it says B16A on the block doesnt make it a b16 at 84x89. thats a b20 sleeper motor. which is neat, jsut not a b16.
i just can NOT stand waiting for the revs to climb with a 77.4mm crank. yea you may be able to rev to the moon but boy do they climb slowly in comparison to an 89mm crank motor.
Old Nov 27, 2006 | 05:47 PM
civic2slo's Avatar
In my sig.
Old Nov 27, 2006 | 08:21 PM
Default "DEF" tones
dont hate man (deftones) just because weve got some awesome b16 kickin butt here....
dont be offended this thread isnt to say they (b16s) reign supreme because of course like i said before if you do have more torque and know how to handle it then OF COURSE read carefully now.... you will yield better times(must have tires, suspension, and clutch= right setup). most people new or semi new to the track cant pull off a good launch with too much torque. just read between the lines b16 are really good motors because of their monetary effenciency and they are really light and still produce good power which is a great option for an already light car (crx)
more displacement is the means for more torque and more torque means go faster but less weight will always be easier to push or pull (rwd) off the line. more torque can make up for the weight but a b16 is a perfect candidate for a crx....
so love it or hate it but keep it real man this all about hondas EVEN YOURS
Old Nov 27, 2006 | 10:22 PM
crx=si's Avatar
Default Re: B16 builds in the 12-14 second 1/4 mile times (xDEFTONESx)
lol, it's actually 86 x 89 b16 , just out of curiousity, what would you call an 86 x 95 motor in a b20?? an H22?
Old Nov 28, 2006 | 10:22 AM
Default Re: to the ******* retard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 &raquo;</TD></TR><TR><TD CLASS="quote">dont hate man (deftones) just because weve got some awesome b16 kickin butt here....
so love it or hate it but keep it real man this all about hondas EVEN YOURS </TD></TR></TABLE>
that was the mot hilarious thing i have read in so long man. thanks.
posting up b16 set ups is one thing, but your absolutely retarded manner of thinking is what makes me laugh so hard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 &raquo;</TD></TR><TR><TD CLASS="quote">yea um so more torque in a heavy car is like a light car with more b16 with less revs and higher suspension means that (rwd) will be the perfect candidate for a crx. but if you put an ls motor in a crx that be more like b16 suspension! cuz then its all about hater,s even rwd! its a push pull situation? yo dawg get at me."</TD></TR></TABLE>
why do you keep trying to say that any one motor is better than another motor for a specific car?
Old Nov 28, 2006 | 10:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx=si &raquo;</TD></TR><TR><TD CLASS="quote">lol, it's actually 86 x 89 b16 , just out of curiousity, what would you call an 86 x 95 motor in a b20?? an H22? </TD></TR></TABLE>
big, relatively speaking?
allnaturalb16, please google the long word that starts with an "r" right there before you come back with one of your infamous super intellectual responses about how the b16 is the perfect candidate for a crx.
Old Nov 28, 2006 | 10:44 AM
RaceCarRyne's Avatar
weight reduction is the key
Old Nov 28, 2006 | 11:11 AM
Default Re: B16 builds in the 12-14 second 1/4 mile times (DC2jdmIntegra)
weight is they key but deftones must be deft because he doesnt seem to get it...
think about it man...im not disagreeing with anything u have to say
put a stock gsr/b20/k20 into a perfectly stock crx = crazy wheel hop/bad traction(from a dig)
now put a stock b16 (or semibuilt)swap into a perfectly stock crx = good ****
this is where i stress RIGHT SETUP meaning traction bars, drag radials/slicks, and tuned suspension to handle the very dramatically increased torque when building a bigger disp. motor.
WHY do you think a geo metro has small tires stock? low tq./weight
WHY do you think a Corvette has big tires and nice suspension? more tq./weight
you have to have a lot more car to handle a lot more power and when your trying to stay light weight and not turn your car into a DRAG car you would definetly consider a b16 or not(im guessing in your case) so go built b18/b20 and then youll have to spend a lot more on other mods to compliment, but this thread being for b16 enthusiasts we are discussing b16s.
now relatively speaking if you dont like b16s or this thread then check out something else......its soooo funny how serious you are and how bad you want to argue but i never contradicted anything you have stated.
never said: torque will make you slower!! i said it would make it more difficult to handle especially off the line meaning you need more mods
but for an easy quick motor the b16 is great for the crx, wanna spend a lot and go faster then GET THE RIGHT SETUP LEARN HOW TO DRIVE AND BUILD YOU A B18 B20 K20 but if you like your B16 and your money still in your wallet like i like mine then keep on postin im seeing some good stuff
Modified by allnaturalb16 at 3:59 PM 11/28/2006
Old Nov 28, 2006 | 03:19 PM
its official. you are honda-tech's biggest ******* moron for the upcoming month of december.
the sad thing about you not making sense, is how HARD you are trying to actually make sense.
oh and, what is "deft"?
will someone please add that quote to their signature, im all outta room. thanks in advance.
