LMA removal question....
Old Nov 24, 2006 | 05:56 PM
Drew17th's Avatar
Default LMA removal question....
alright i have a b16a head im about to put a supertech valvetrain with s2s2 cams.... i was told to get some gsr lma's instead of the b16 lma's....
is this wise???
and if so how the heck do i get them outa my blown gsr head i have laying around???
If any1 is wondering the setup its a fully rebuilt jdm type R block with the b16 head supertech valvetrain witht the supertech high compression valves and debating on either pro 1's, pro 2's, or some bc 4's....
thx in advance!!!
Old Nov 24, 2006 | 06:13 PM
Brick Top's Avatar
Default Re: LMA removal question.... (Drew17th)
very wise to do this. the rocker arms and rails must be removed for the lma to pull out.
Old Nov 24, 2006 | 06:28 PM
EFsSuck's Avatar
Default Re: LMA removal question.... (brick top)
yeah deff have to pull the rails/rocker assy out...
https://honda-tech.com/zerothread/1817224 <~take a look at that too...make sure your putting the right LMA in your motor
Old Nov 24, 2006 | 06:45 PM
PURE Tuning's Avatar
Default Re: LMA removal question.... (EFsSuck)
Also Be sure to keep your rocker assemblies in sets and proper location.
Old Nov 24, 2006 | 06:50 PM
EFsSuck's Avatar
Default Re: LMA removal question.... (PURE Tuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURE Tuning &raquo;</TD></TR><TR><TD CLASS="quote">Also Be sure to keep your rocker assemblies in sets and proper location.</TD></TR></TABLE>
why?
Old Nov 24, 2006 | 07:09 PM
98vtec's Avatar
moderator emeritus
why not?
Old Nov 24, 2006 | 07:12 PM
EFsSuck's Avatar
Default Re: LMA removal question.... (B.Rabbit)
im just asking if there is a reason to... if he is replacing the cams there is no reason for them to go back into the same spot, even then there really isnt. you would have to do a valve adjustment anyway.
Old Nov 25, 2006 | 01:58 PM
Drew17th's Avatar
lol ok kool... yea the gsr LMA's i have on the blown head definantly have the bigger surface flat surface.... so i guess can any1 explain how to get the rocker arms and then the LMA's out??? never had to take em out lol...
and just for curiousity sake.. why is it important to get the bigger surface LMA's???
thx
Old Nov 25, 2006 | 02:44 PM
EFsSuck's Avatar
pretty easy to remove... first you need to start by going to Sears and getting a 10mm allen head socket. you will need it to get the caps off the end of the head. there are 3 of them. two on the cam gear side and one under the dizzy. remove all them and dont lose the washers (your suppose to replace them though). oh and there are little orifice tube things that hide under the caps on the dizzy side of the head, you need to find a bolt that threads in so you can pull them out. then jam your finger in the hole lol and push the rod out the other side. like they said you want to keep the rockers all together cuz there are little bearing/pins in them, if you lose them your fucked (Honda only sells them with the rocker pad set ~$150)....
install is just the reverse... good luck
oh and i dont think its so much the surface as there is a higher spring rate in the LMA in the later GSR/ITR's...
Old Nov 25, 2006 | 02:47 PM
EFsSuck's Avatar
http://www.crxpower.net/~silve...a.pdf &lt;~right click, Save As... FULL FACTORY SERVICE MANUAL for a 94+ teggy... 1600pages of goodness... you cant find the answers in there, you probably arent suppost to take it apart lol
Old Nov 25, 2006 | 05:13 PM
It is important to keep the factory matched sets than exact location. It is good practice to keep the proper locations of all valvetrain components.
Old Nov 26, 2006 | 09:11 AM
Drew17th's Avatar
that book thing didnt work... so who wants to explain how to get LMA's out????
thx
Old Nov 26, 2006 | 09:32 AM
1 2 NV's Avatar
at this point if you havent looked at the head and figured it out you probably shouldnt be working on such a project. i have little faith this project will be finished by you and you only.
Old Nov 26, 2006 | 11:47 AM
Drew17th's Avatar
Default Re: LMA removal question.... (1 2 NV)
wow ok..... first of all it will be but when u have never removed them its kinda weird.... i have removed the 3 allen head bolts and washers and then i threaded a bolt in to get the rails out but they wont budge....
im more trying to figure out the LMA's...
do they just pop out once the rocker arms are out or what???
Old Nov 26, 2006 | 11:54 AM
1 2 NV's Avatar
alright, now your getting somewhere. there are 2 "pins" that sit down inside the head underneath the first cam caps on the cam gear side. pull those out and then your rocker arms will slide out.
Old Nov 26, 2006 | 11:55 AM
EFsSuck's Avatar
yeah you need to remove...
#'s 3 and 4.... they are holding the rods in place from sliding out...
90B16aCRXsi
43
Jul 30, 2008 08:50 PM
crawlin
Oct 20, 2006 07:00 PM
DRIVENRacing
Apr 16, 2005 04:37 AM
Hybrid CRX
Mar 22, 2004 07:50 AM
granada_sun
Jun 25, 2003 10:00 PM
