What is wrong with the paint on this rim?
Old Nov 24, 2006 | 02:14 PM
SunshineCivic's Avatar
Default What is wrong with the paint on this rim?
Hello HTer~~
Does anyone know what is wrong with the paint on this rim~ I know that the previous owner painted it himself~ Is it because he did not probably sand it down that is why there is wrinkle~ And finally do you think if I spend time sanding it down I can paint it so it's all smooth and nice?
Thanks guys ^-~
Jess
Old Nov 24, 2006 | 02:20 PM
m R g S r's Avatar
Default Re: What is wrong with the paint on this rim? (SunshineCivic)
looks like improper sanding/drying
Old Nov 24, 2006 | 02:23 PM
Default Re: What is wrong with the paint on this rim? (m R g S r)
Thanks Q~
Can it be fixed totally by properly sanding/painting/drying it again~
Thanks again
Old Nov 24, 2006 | 02:25 PM
Here is a bigger pic
Old Nov 24, 2006 | 02:29 PM
fycus's Avatar
looks like he painted with a brush . Just sand it down and redo it.
Old Nov 24, 2006 | 02:30 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
definitely bad sanding, or it was painted to heavily or in bad temperature, just strip that **** off and redo it the right way
Scotty Dosent Know's Avatar
Use aircraft stripper to remove all the old paint, sand them smooth, primer them then re-paint!
Old Nov 24, 2006 | 02:32 PM
Default Re: (ecko1980)
Thanks you people
Old Nov 24, 2006 | 03:52 PM
StylishDOHC's Avatar
Default Re: (SunshineCivic)
looks like it was stripped with 36 grit sandpaper
Old Nov 24, 2006 | 03:55 PM
qwk db8's Avatar
Default Re: What is wrong with the paint on this rim? (fycus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fycus &raquo;</TD></TR><TR><TD CLASS="quote">looks like he painted with a brush . Just sand it down and redo it. </TD></TR></TABLE>
thats what i was thinking
Old Nov 24, 2006 | 04:45 PM
RC_Benjamin's Avatar
Default Re: What is wrong with the paint on this rim? (qwk db8)
brush painted 100%
Old Nov 24, 2006 | 04:49 PM
barely4dr's Avatar
sand it down and start over.
Old Nov 24, 2006 | 04:50 PM
NIKE SB'd's Avatar
clean/prep the wheels better it look like there were contaminanents on the wheel when it was painted which causes the pop you are now seeing.
Old Nov 24, 2006 | 07:37 PM
DB1_559's Avatar
its brushed on no doubt
masijdm
Apr 20, 2009 05:55 AM
sawjai526
Paint and Body
Sep 7, 2008 10:13 AM
b16-t
Paint and Body
50
May 10, 2008 08:49 PM
JonnySBeee...
Feb 25, 2005 10:49 AM
jg
Aug 27, 2002 07:23 PM
