Turbonetics To4E,, Ramhorm Manifold, 3inch Dp
Old Nov 24, 2006 | 12:27 PM
OBRJosh's Avatar
Default Turbonetics To4E,, Ramhorm Manifold, 3inch Dp
EVERYTHING IS SOLD SOLD SOLD
Hey whats Going on Im selling this stuff Cheap Ive decided to run a BIgger Turbo and a topmount, See from Pictures PM ME any questions or price offer Thanks...... Josh
TurboNectics To4e 60trim .69 ar on center comes with Function7 oil feed and drain fitting
Compresser blade has small chip on 1 blade and spools perfect, Zero Shaft Play, ran 13.3@ on stock b16 on 8psi $350 OBO
Stainless Steel Ramhorn Oncenter with 38mm Flange $375 $400 with DP
Modified by OBRJosh at 4:55 PM 11/24/2006
Modified by OBRJosh at 10:10 PM 11/24/2006
Modified by OBRJosh at 12:42 AM 11/25/2006
Modified by OBRJosh at 12:43 AM 11/25/2006
Modified by OBRJosh at 2:36 PM 11/26/2006
Modified by OBRJosh at 1:04 AM 11/27/2006
Modified by OBRJosh at 1:04 AM 11/28/2006
Modified by OBRJosh at 11:01 AM 11/28/2006
Modified by OBRJosh at 12:41 AM 12/9/2006
Old Nov 24, 2006 | 06:12 PM
OBRJosh's Avatar
Default Re: Turbonetics To4E,, Ramhorm Manifold, 3inch Dp (OBRJosh)
Bump Need to sell
Old Nov 25, 2006 | 09:24 AM
OBRJosh's Avatar
Saturday Bump
Old Nov 25, 2006 | 09:55 AM
StolenTeg's Avatar
Do you know who make the manifold? Also, is it a 38mm wastegate? one of the picture showed a different flange or did you cut that and weld a 38mm flange on?
Is the downpipe also a 4 bolt flange that would fit my sc34 with 4 bolt exhuast housing?
Old Nov 25, 2006 | 09:57 AM
OBRJosh's Avatar
Default Re: Turbonetics To4E,, Ramhorm Manifold, 3inch Dp (StolenTeg)
Dp is 4bolt and Manifold is made by Silly_ Sohc on HT, Yea the vband Flange was cut off Cause ,I ran a 38mm Wastegate the guy i bought it from ran a Vbanb 48mm The turbo has maybe 2500Miles Max on it spins great, and sounds awesome spooling I posted this stuff to sell so let me know what you want and i can hook it up for ya
Modified by OBRJosh at 2:07 PM 11/25/2006
Modified by OBRJosh at 2:09 PM 11/25/2006
Old Nov 25, 2006 | 10:12 AM
StolenTeg's Avatar
Do you happen to have this off the car? if possible i would like to see a shot of the collector and the head flage
Btw, where are you in CT?
Old Nov 25, 2006 | 10:22 AM
OBRJosh's Avatar
New Haven Ct
Heres a pic from When my buddy had it, Its off the car now, but the turbo is on the manifold ,Also Its a ONcenter Flange to match the Turbo, a Tang flange turbo prolly with fit but not sure
Old Nov 25, 2006 | 03:13 PM
OBRJosh's Avatar
Bump for great package deal All reasonable offers takin
Old Nov 25, 2006 | 05:01 PM
quis84's Avatar
so the manifold is t4 flanged correct free bump
Old Nov 25, 2006 | 05:13 PM
OBRJosh's Avatar
Default Re: (quis84)
Yes T4 Flange
Old Nov 25, 2006 | 05:45 PM
jz98ctr's Avatar
bizziggity bump nukka
Old Nov 26, 2006 | 10:37 AM
OBRJosh's Avatar
Default Re: (jz98ctr)
Turbo lowered to $300 Still taking offers Priced to sell hit me up
Modified by OBRJosh at 3:34 PM 11/26/2006
Old Nov 26, 2006 | 06:08 PM
OBRJosh's Avatar
Default Re: (OBRJosh)
Come on people Package deal for mani, turbo, Dp Cheap Cheap!!!!
Old Nov 27, 2006 | 11:25 AM
OBRJosh's Avatar
Bump BUmp BUmp itup
Old Nov 27, 2006 | 06:40 PM
OBRJosh's Avatar
Old Nov 27, 2006 | 08:59 PM
wannarace07's Avatar
* B A N N E D *
how much for mani
Old Nov 27, 2006 | 09:01 PM
OBRJosh's Avatar
Default Re: (wannarace07)
$375
Old Nov 28, 2006 | 06:02 AM
jz98ctr's Avatar
ONLY 3 HUNJ for the turbo!!!!??????
I might have to scoop that man!!!
Old Nov 28, 2006 | 06:40 AM
quis84's Avatar
whats the chance of this manifold fitting in a crx
Old Nov 28, 2006 | 06:42 AM
JDMs1eeper's Avatar
good deal, bump!
OBRJosh's Avatar
If you have a half size rad and put it on anangle it will fit
Old Nov 28, 2006 | 07:26 AM
OBRJosh's Avatar
TURBO IS SOLD SOLD SOLD!!!!!!!
Old Nov 28, 2006 | 01:50 PM
OBRJosh's Avatar
manifold Left With 3inch Dp
Old Nov 28, 2006 | 07:50 PM
OBRJosh's Avatar
Bump Bump
Old Nov 28, 2006 | 10:47 PM
jz98ctr's Avatar
early in the morn bump
