Hey guys whats Tranny is this???
Old Nov 24, 2006 | 10:51 AM
Jason703Racing's Avatar
Default Hey guys whats Tranny is this???
Numbers on the trans are the following.
S80 2020454
I was told a b16 lsd tranny but want to know for sure.
Old Nov 24, 2006 | 11:08 AM
word itz chris's Avatar
Default Re: Hey guys whats Tranny is this??? (Black00em1)
Its an S80 transmission.
Yes, its B16 LSD.
Old Nov 24, 2006 | 11:19 AM
og asr's Avatar
Default Re: Hey guys whats Tranny is this??? (word itz chris)
Isn't s80---gsr?
Old Nov 24, 2006 | 12:05 PM
revlimit69's Avatar
yes S80 is the later B18C box, came out after the Y80 with slightly shorter ratios.
Old Nov 24, 2006 | 02:43 PM
T4eg's Avatar
Default Re: (revlimit69)
just look through and make sure its lsd
Old Nov 24, 2006 | 02:53 PM
HamiltonRex's Avatar
Default Re: (T4eg)
my gsr trans says s80, look though diff to see if LSD or not.
Old Nov 24, 2006 | 06:54 PM
Runnerdown's Avatar
Default Re: (HamiltonRex)
s80 is not b16, its either gsr or type r
Old Nov 25, 2006 | 03:09 AM
Default Re: (Runnerdown)
was 1200 does that matter?
Old Nov 25, 2006 | 05:01 AM
harhoosh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">s80 is not b16, its either gsr or type r</TD></TR></TABLE>
Old Nov 25, 2006 | 05:29 AM
Default Re: (harhoosh)
at 70 mph I tack 4000 any ideas?
Old Nov 25, 2006 | 05:42 AM
tricura's Avatar
Default Re: (Black00em1)
sounds like a b16, but maybe the final drive has been changed
Old Nov 25, 2006 | 01:00 PM
Default Re: (tricura)
Its a JDM trans i think. I got it from a local shop qouting it was a b16 lsd tranny , maybe type r?
Old Nov 26, 2006 | 12:25 AM
CoreyR's Avatar
honda is stupid. s80 can be like 48 different trannies. i CAN be a JDM CTR tranny w/lsd yes. it can also be a GSR/ITR/LS tranny also. best way to tell like other people said, look throigh the differential and if you can see right through it its LSD, if its got a metal rod going through it, you got jacked.
Old Nov 26, 2006 | 12:27 AM
CoreyR's Avatar
Default Re: (CoreyR)
actually, if its doing 4K at 70 its not a B16 tranny of any type. sounds like a GSR to me.
Old Nov 26, 2006 | 01:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black00em1 &raquo;</TD></TR><TR><TD CLASS="quote">at 70 mph I tack 4000 any ideas?</TD></TR></TABLE>
Thats nothing, try 65 @ 4350. **** sucks.
Old Nov 26, 2006 | 10:26 AM
choreboy's Avatar
yes s80 is gsr or ls, if its not lsd,you paid to much.
Old Nov 27, 2006 | 04:42 AM
ATYPR's Avatar
what size tires do you have on your car?
BTW, it sounds like you may have a JDM ITR trans.
Old Nov 27, 2006 | 06:13 AM
tricura's Avatar
Default Re: (FUCATYPR)
stock GSR with stock wheels will do 4k @ 80mph, put a b16 trans into an Integra it will do 4k @ 70mph. These are oem trans figures. If it has been opened up or if the wheels are not stock sizing all that will come into play.
Old Nov 27, 2006 | 08:53 AM
Gearspeed-Performance's Avatar
S80 can be the following:
96-up GSR
96-up LS (be careful)
96-up TYPE R both JDM or USDM
They all have this tag code...be careful.
AN S80 is <U>not</U> a B16!
Y80 is all hydro Integra 94-95 5spd transmissions...GSR and LS.
CTR will have a tag code of S4C with an LSD. This is also the same tag code of the 99-00 Civic Si which does not have an LSD.
<U>Half the information in this post topic is wrong so be careful</U>
Old Nov 27, 2006 | 08:54 AM
Default Re: (choreboy)
I took the axle out found out it does have a lsd. here's my new question. will a oem lsd hold 400 hp and launching on slicks?
Old Nov 27, 2006 | 09:41 AM
CoreyR's Avatar
Default Re: (GearSpeedEF7)
cant argue with the guys who build trannies for a living i guess. i always thought S4C was CTR but all the information ive ever seen posted claimed a CTR tranny could be labeled S80.
Old Nov 27, 2006 | 10:37 AM
SLIM NOTHING
Transmission & Drivetrain
30
Jan 25, 2011 11:42 AM
Alexpbnj
11
Sep 21, 2010 12:27 PM
turbo boost
Aug 20, 2008 04:57 PM
thad
Mar 27, 2004 10:27 PM
LBDM EK97
Mar 20, 2004 07:40 PM
