How can you tell if a catalytic converter is bad?
Old Nov 24, 2006 | 09:11 AM
invisible's Avatar
Default How can you tell if a catalytic converter is bad?
I need a new cat and Im buying a used oem one. is there anyway I can check to see if its bad? What do I need to look for? He said he had check engine light but it was becuase of his O2 sensor..
Old Nov 24, 2006 | 09:39 AM
Eran's Avatar
HT White Ops
if you hold it up to a light and rotate it, you should be able to see a pinhole at EVERY angle.
Old Nov 24, 2006 | 10:35 AM
Nameless Warrior's Avatar
Default Re: (Eran)
Eran,
You're a civic guru aren't cha?
Old Nov 24, 2006 | 10:38 AM
Eran's Avatar
HT White Ops
Default Re: (Nameless Warrior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless Warrior &raquo;</TD></TR><TR><TD CLASS="quote">Eran,
You're a civic guru aren't cha?</TD></TR></TABLE>
Not half as much as I think I am, nor a 10th what I wish I was
Old Nov 24, 2006 | 11:07 AM
invisible's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">if you hold it up to a light and rotate it, you should be able to see a pinhole at EVERY angle.</TD></TR></TABLE>
ok thanks. is there anything else? how do i know if it was 'gutted'?
Old Nov 24, 2006 | 11:12 AM
EL Vap133's Avatar
Default Re: How can you tell if a catalytic converter is bad? (Battle23)
Lack of performance, bad gas mileage, smells like crap, hear a rattling noise in some cases.
Old Nov 24, 2006 | 01:42 PM
FRWYKNG's Avatar
Default Re: How can you tell if a catalytic converter is bad? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Lack of performance, bad gas mileage, smells like crap, hear a rattling noise in some cases. </TD></TR></TABLE>
Following with a bad O2 sensor, and ya the rattling is #1
Old Nov 24, 2006 | 01:56 PM
invisible's Avatar
Default Re: How can you tell if a catalytic converter is bad? (450oNSLiCkS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 450oNSLiCkS &raquo;</TD></TR><TR><TD CLASS="quote">
Following with a bad O2 sensor, and ya the rattling is #1</TD></TR></TABLE>
Well it's out of the car already.
Old Nov 24, 2006 | 02:56 PM
bsixteen's Avatar
Default Re: (Battle23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Battle23 &raquo;</TD></TR><TR><TD CLASS="quote">
ok thanks. is there anything else? how do i know if it was 'gutted'?</TD></TR></TABLE>
if you look down the pipe and there's nothing in it..then its gutted
Old Nov 25, 2006 | 10:24 AM
invisible's Avatar
Default Re: (bsixteen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsixteen &raquo;</TD></TR><TR><TD CLASS="quote">
if you look down the pipe and there's nothing in it..then its gutted</TD></TR></TABLE>
Is this what its suppose to look inside? http://i21.photobucket.com/alb...8.jpg
Old Nov 25, 2006 | 10:28 AM
o_fatmike_o's Avatar
f*k the converter and just str8 pipe it!!!
Old Nov 25, 2006 | 10:33 AM
EK k kay's Avatar
Is this what its suppose to look inside? http://i21.photobucket.com/alb...8.jpg</TD></TR></TABLE>
Yes
Old Nov 25, 2006 | 10:56 AM
invisible's Avatar
Default Re: (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">
Yes</TD></TR></TABLE>
how do they go bad in the first place? would a bad cat were to go bad on its own, would it look like its gutted?
G2_Fella
Jul 22, 2008 08:25 PM
G0crxG0
Jun 2, 2006 07:23 AM
civicd16ex
12
Oct 27, 2005 06:29 PM
imjac1
Mar 5, 2005 07:22 PM
coot_er
Acura TL, RL & ZDX
Nov 27, 2004 11:42 AM
