rim wobble
Old Nov 23, 2006 | 07:25 PM
k7q's Avatar
k7q
Default rim wobble
my front right wobbles. i think the rotor is moving. ill have to check again tomorrow. i try to tighten the 2 screws for the rotor, but they were tighten already.
can it be the tie rod?
(before you guys start flaming me about checking it, i got out of surgery for my thumb not too long ago and im still recovering.)
Old Nov 23, 2006 | 07:43 PM
john666's Avatar
Default Re: rim wobble (k7q)
jack up the car and wiggle the right tire to see if it has any play.
Old Nov 23, 2006 | 07:48 PM
jrs2ksi's Avatar
could be ur right axle or the tie rod. My wheel wobled bad when my axle went to ****. Jack it up and check those both.
I know how u feel....i tore my knee at work and im on crutches.....cant work on my car untill i can stand on it again. Good luck tho.
Old Nov 23, 2006 | 07:50 PM
EGwhat!!!'s Avatar
Default Re: rim wobble (jrs2ksi)
it could be the tires arent balanced
Old Nov 23, 2006 | 08:37 PM
nva2nd's Avatar
Hit any huge pot holes lately?
Old Nov 23, 2006 | 08:47 PM
k7q's Avatar
k7q
Default Re: rim wobble (nva2nd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">jack up the car and wiggle the right tire to see if it has any play.</TD></TR></TABLE>
i can kick the rim while it's on the ground and it wiggles left and right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrs2ksi &raquo;</TD></TR><TR><TD CLASS="quote">could be ur right axle or the tie rod. My wheel wobled bad when my axle went to ****. Jack it up and check those both.
I know how u feel....i tore my knee at work and im on crutches.....cant work on my car untill i can stand on it again. Good luck tho.</TD></TR></TABLE>
how do i know is my tie rod is bad? the axle seems ok.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! &raquo;</TD></TR><TR><TD CLASS="quote">it could be the tires arent balanced</TD></TR></TABLE>
their balanced. i had them on another car without any problems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nva2nd &raquo;</TD></TR><TR><TD CLASS="quote">Hit any huge pot holes lately?</TD></TR></TABLE>
nope.
Old Nov 23, 2006 | 09:25 PM
vsmhatched's Avatar
possible wheel bearing
Old Nov 23, 2006 | 09:44 PM
k7q's Avatar
k7q
Default Re: rim wobble (GreyDel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreyDel &raquo;</TD></TR><TR><TD CLASS="quote">possible wheel bearing</TD></TR></TABLE>
i searched and read that if a wheel bearing is bad it would make howling noise, but i don't hear any howling noise.
Old Nov 23, 2006 | 11:01 PM
EH6TunerDaniel's Avatar
It could also be a bad bushing in the control arm, that happened to me with the same symptoms.
Old Nov 23, 2006 | 11:26 PM
k7q's Avatar
k7q
Default Re: (EH6TunerDaniel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH6TunerDaniel &raquo;</TD></TR><TR><TD CLASS="quote">It could also be a bad bushing in the control arm, that happened to me with the same symptoms.</TD></TR></TABLE>
upper or lower control arm?
EDIT: ill just check both tomrrow. hopefully there isn't much pain in my thumb.
Old Nov 24, 2006 | 12:11 AM
Lower on mine.
Old Nov 24, 2006 | 02:55 PM
k7q's Avatar
k7q
hmm i just checked it and it seems that the axle nut is loose? can that make my wheels wobble?
Old Nov 24, 2006 | 04:44 PM
viahiptop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k7q &raquo;</TD></TR><TR><TD CLASS="quote">hmm i just checked it and it seems that the axle nut is loose? can that make my wheels wobble?</TD></TR></TABLE>
eventually the axle will come apart if you dont properly torque it down
Old Nov 24, 2006 | 06:48 PM
EG2Driver's Avatar
Default Re: rim wobble (viahiptop)
could be a lower ball joint. Mine had play in it. When i came to remove it, the nut would jus spin. That balljoint was done for. Thats most likely what it is since it is not a bearing.
Mendes
Feb 21, 2008 01:46 PM
lyzer227
Feb 12, 2008 01:49 AM
jrap1243
Oct 21, 2007 12:26 PM
zach1288
20
Sep 18, 2007 08:17 AM
DraginTeg93
Nov 20, 2006 12:20 PM
