throwing a code 2
Old Nov 23, 2006 | 04:54 PM
beroll_eg6's Avatar
Default throwing a code 20
i just got my car swapped out and im running obd2 in an eg cause i wanna run the type r ecu. but im getting a cel for a code 20. does anyone know how to fix this? its teh eld. something like that
Modified by beroll_eg6 at 7:50 PM 11/23/2006
Old Nov 23, 2006 | 08:31 PM
civicstar's Avatar
Default Re: throwing a code 20 (beroll_eg6)
seems to be something in the wiring, most likely somewhere in the engine wiring harness, check around the alternator and the wires that run to it
Old Nov 23, 2006 | 09:42 PM
beroll_eg6's Avatar
i think im just gonna buy another engine harness and go from there. ive got alot of feedback telling me that it was in the alternator.
Old Nov 23, 2006 | 09:51 PM
igotthaspirit's Avatar
The ELD is inside the underhood fusebox.
Old Nov 23, 2006 | 09:57 PM
civicstar's Avatar
well with my auto 4 dr civic, i had that problem too and i changed the harness and it seemed to do the trick
Old Nov 24, 2006 | 07:16 PM
beroll_eg6's Avatar
i swapped out the fuse box under the hood wit ha jdm type r one that came with the front clip i purchased and it did the same thing. my next step is to change the wiring. and ill see from there
nkuser
Nov 20, 2020 08:36 PM
LSdelsol
Jul 23, 2011 06:29 PM
DxBurnoutKing
May 19, 2005 01:12 PM
