prelude alternator question.. read me
i have a h22 swap in my eg.. my question..
i was driving my car then i through it in netural and the car died.. i wasn't running on an alternator belt becuase my belt was loose and got rip bad.. i had a buddy use jumper cables to charge my battery but it won't crank over where it will run.. it will crank but wont' run.. i change distributor on check for spark, i have fuel both fuel pump and injector, i have compression on all 4 cyclinder, and my timing is still correct.. could it be that since i don't have an alternator belt it could reduce the amount of spark i receive to the distributor?? any suggestion would be great.. and also i change my ecu, still not working and triple check all my wiring making sure nothing got unplug..
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dapump2003 »</TD></TR><TR><TD CLASS="quote">i do have an alternator, just no alternator belt... the belt was loose and it snap on me... any suggestion on my questiOn??</TD></TR></TABLE>
You have an alternator but no belt? So perhaps I should have been more specific...You need to have a working alternator for your car to run...sigh
Kinda hard to keep the battery charged if nothing is keeping the alternator spinning. Never heard of anyone running no alternator belt.
Is it that hard and expensive to replace a belt you need?
nope it isnt' hard to replace just never had the chance to get to it.. well n e waise i bought a new alt belt and still no luck.. car crank but won't run.. i thinking it might be eletrical?? i readjusted my timing on my cam gear to 0 degree...
We need to know what you have, spark, fuel press, fuel injection, timing, compression then we can continue, it should run from a jump start. Are you sure you didnt accidently cross the jumper cables, or your friend, it happens, not embarassing, check all fuses under the hood too.
i have spark, fuel and i am getting fuel in each injector, my timing is set on 0 degree on my cam gear, i have compression on all 4 cyclinder... i check the voltage on my battery, and came out fine.. triple check my wiring making sure no wiring is touching each other and made sure all ground is grounded properly.. all fuses is a OK... and swap the ecu 4 times.. ??
excuse me but i am very confused...correct me if im wrong: 1) your alternator belt broke and you drove the car for some time with no belt...
2) the battery now will not hold a charge
let me know..it will be easier to help out
my alternator belt snap on me.. came back home .. turn the car off and left it there for a day... the i was suppose to race this mustang for some cash, so i prep my car and drove it maybe 1/8 of a mile and the car died.. every since then it wouldn't work.. and yes i drove it without an alternator belt...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dapump2003 »</TD></TR><TR><TD CLASS="quote">my alternator belt snap on me.. came back home .. turn the car off and left it there for a day... the i was suppose to race this mustang for some cash, so i prep my car and drove it maybe 1/8 of a mile and the car died.. every since then it wouldn't work.. and yes i drove it without an alternator belt...</TD></TR></TABLE>
ok 1. you have horrible grammar
2. you are not very intelligent
3. I DONT HELP STOOPID RICEY STREET RACERS....
good luck..figure it out on your own
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dapump2003 »</TD></TR><TR><TD CLASS="quote">the i was suppose to race this mustang for some cash, so i prep my car </TD></TR></TABLE>
i lol'd. wow you are dump. i'll almost put you with that dude who was crying around his sunroof after he let his friend sit on it.
Just sell your car now please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dapump2003 »</TD></TR><TR><TD CLASS="quote">expletive you.. ******* loser.. karma is a bitch and it will kick you in the ***.. i hope you ******* car die too..bitch</TD></TR></TABLE>
Wow.....All kidding aside, ignorance has hit a new low in you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dapump2003 »</TD></TR><TR><TD CLASS="quote">you ****** Nc people don't know **** n e waise.. stupid as$ white boy.. karma is gonna kick you ****** as$ to... your car will died bitch, and nobody will help you *** out</TD></TR></TABLE>
your are one ignorant piece of shitl. i hope your car blows up.
let me just ask one thing....
Is it gang related where you're from....the last person that called someone a white boy on here told me it was gang related where he's from....
Turns out he lost his ***** in a crazy airplane accident some time ago....
I suggest you remove your head from your ***. Did you check for spark yet?
since i dont know ****...make sure you have a good battery...a belt on your alternator, and spark..if you dont have spark..check the coil and ignition module (ignitor) for spark..then get back to us
once again, you displayed more great grammar...i dont know **** because im not from cool *** cali and i use a belt on my alternator and attended english class(i guess that makes sense)...anyway my car wont die because i have a brain..secondly you have no idea who i am and who i can get help from IF i even need it...dont come on here cool breeze and try to stunt with that street racing story you so nonchalantly slipped into an otherwise legit post...
PLEASE refrain from racial slurs..you wouldnt want them repeated on you..would you???
