control arm issue with ITR suspension on a GSR
i have a 98 dc2 running a dc2-R suspension setup consisting of the stock dc2-R shocks, springs, and rear control arms. this setup dropped my car about 13mm. and maybe it's just me but there seems to be a degree or two of camber in front and none in the back. is this due to the fact that i have dc2R rear control arms? if i get dc2R front control arms will that rectify the camber if indeed there is some? as you can see i am a little lost. any help would be greatly appreciated.
Have you actually gotten an alignment and had the camber measured? If camber is important to you then Toe should be as well so you need an alignment anyway.
