92 Eg hatch suspension
I have a problem with my camber. I have a 92 hatch with GSR brakes and suspension. The upper control arm and camber kit are not stock, but my lower control arm and spindle are. I was told to fix the camber that i would have to put GSR lower control arms and that will tow the bottom back in. I did that and when i took the stock control arms off they were the same size as the GSR lower control arms and therefore the tires are still towed way to far in. I was wondering if i needed GSR front spindles because possibly the brakes stick out to far. Any info. on this topic will be greatly appreciated because im getting sick of buying new tires every month
Re: 92 Eg hatch suspension (BlueIntegraBoy)
No you don't understand. I have a skunk2 upper camber kit but the uppercontrol arm is towed all the way out. The bottom is still sticking way too far out, so it is towed in way too far
I got the brakes off a 94-97 GSR and also that is where i got the control arms, and they were the same size as my stock control arms.
idreamHonda
Suspension & Brakes
04-16-2005 01:44 PM
