Quick question regarding to Skunk2 full coilover set.
i have this brand new set of skunk2 coilover kit with part number 541-05-5720
1994-01 ACURA INTEGRA (NON TYPE R)/1992-95 CIVIC (ALL MODELS)
and would like to know if i can make it to fit on 96-00 Civic
i am sure there must be a way around it
someone please help
thank you so much
someone please help
thank you so much
Yes you can. The front will fit correctly with no problems, while the back you'll have to use washers to fill the space btw the shock and the lower control arm. You'll see when you go to install them. But to answer your question, yes it will work on a 96-00 Civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-Lug »</TD></TR><TR><TD CLASS="quote">Yes you can. The front will fit correctly with no problems, while the back you'll have to use washers to fill the space btw the shock and the lower control arm. You'll see when you go to install them. But to answer your question, yes it will work on a 96-00 Civic</TD></TR></TABLE>
Thanks for the quick reply man..
one more question why does it say Non-ITR model? what's up with that? coz of the LCAs or what? possible to make it fit on ITR as well?
thanks
thanks
bdb
31
May 28, 2003 03:39 AM
