car died last night and i cnt figure out why
Old Nov 23, 2006 | 08:30 AM
3.point.2's Avatar
Default car died last night and i cant figure out why
last night while driving my car just shut off, luckily i was able to coast to a safe parking spot. i need your guys help figuring out the problem. the fuel pump and main relay are both fine, theres no blown fuses, the spark plugs look good and the dizzy cap looks good. the stereo and all the lights work so it shouldnt be a battery issue.
heres the unusual part. sometimes when i try to start it then take the key out it makes a sound like the motor stalled only the motor was never on. also when i try to start it the sound of the engine trying to turn over is not constant. i dont think i can explain the sound well enough but ill try. if i keep trying to start it, once every 2 seconds or so the sound of the engine trying to turn over becomes a little deeper like the engine is hesitating.
please someone help me out if they can. also if my descriptions are unclear of what is happening please let me know and ill try to explain it as best as i can.
Old Nov 23, 2006 | 09:53 AM
4dOoR-Ex's Avatar
did u look at the timebelt..
Old Nov 23, 2006 | 10:12 AM
dark_samurai73's Avatar
Default Re: car died last night and i cant figure out why (h23eg)
this may or may not be it but i had a similar shut off problem w/ my 93 sol, i checked the entire ignition system, fuel system, and it ended up being just vapor lock, it would die on me out of nowhere, and start like 20 minutes later, loosen your gascap a little and see if it starts
Old Nov 23, 2006 | 10:44 AM
1slowhatchie's Avatar
Default Re: car died last night and i cant figure out why (dark_samurai73)
check if you get any spark to the plugs i think its ure dizzy gone bad
Old Nov 23, 2006 | 10:51 AM
jdeemseerx's Avatar
spark, fuel, and timing.. start off with the basics.
w0ng_sta
Jan 31, 2007 12:41 PM
importnoodles
Sep 28, 2006 12:22 PM
Spooled1.6L
Apr 20, 2004 05:49 AM
RedCRX
13
Nov 17, 2003 08:06 PM
93egsi
20
Aug 26, 2003 02:54 AM
