For those with PS removed
Old May 8, 2002 | 11:51 PM
simple4012's Avatar
New User
Default For those with PS removed
How did you guys have ya rack setup? I dont whether to loop the feed and return lines on the rack to leave em hanging. I have heard both. Please any opinions or links are greatly appreciated
Old May 8, 2002 | 11:57 PM
sgT's Avatar
sgT
Default Re: For those with PS removed (simple4012)
I looped mine.
Old May 9, 2002 | 12:26 AM
Mario's Avatar
If you want to go the distance & don't feel like looping the lines...check out the "how to" on the page below.
http://pages.sbcglobal.net/mgineering/garage.html
Old May 9, 2002 | 12:35 AM
koy's Avatar
koy
New User
Default Re: For those with PS removed (Supersonic DC2)
this method works well ....so far
Old May 9, 2002 | 04:09 AM
Track rat's Avatar
Default Re: For those with PS removed (koy)
I read that the Realtime guys plumbed a supply and return line into a small vented reservoir. This opened up the loop to relieve pressure and the ps fluid still provided lubrication. Sounds easy.
Old May 9, 2002 | 05:03 AM
Che Guevara's Avatar
Default Re: For those with PS removed (Track rat)
Does this really make a noticeable difference? Just curious.
Old May 9, 2002 | 05:45 AM
nerdish's Avatar
Default Re: For those with PS removed (MarkhamR)
Noticeable? Sure, it'll be a bitch to turn the wheel when you aren't moving!
Performance wise, not /really/ but every little bit counts.
Old May 9, 2002 | 05:47 AM
nerdish's Avatar
Default Re: For those with PS removed (nerdish)
I didn't realize there were so many steps to removing the power steering! Everyone always says you unscrew something, take the belt off, take the pump out, voila. What's all this stuff about? Is this a more permanent way to do it?
What are the disadvantages of the shorter way??
Old May 9, 2002 | 05:50 AM
Back in Black's Avatar
Rather OG
Yes, you can remove the pump, install a manual rack, etc...
You mean removing the belt? Only one that I can think of...weight.
Jason-
who loves the lack of power steering while on track
[Modified by Vader in NC, 9:50 AM 5/9/2002]
Old May 9, 2002 | 05:58 AM
Dropspeed's Avatar
Correct. I copied the way Realtime did theres. I double the feed lines back together and "T" ed into the metal feed line in the center of the rack (looks like a brake line) and ran it up to a Tilton brake resivour that is used as a breather/pressure relief. My car steers almost as easy as when it had power steering.
Mattj
Adriano
Welding / Fabrication
Nov 11, 2007 02:21 PM
jeef84
11
Mar 17, 2005 10:56 AM
dirtySOHC's
Jun 5, 2003 01:10 PM
