ITR sway bars
Old Nov 23, 2006 | 02:37 AM
n1ghthawk's Avatar
Default ITR sway bars
Hi
I have 97 EX and I am doing 5lug conversion. I have also ordered both ITR sway bars. Question is, will they fit my coupe?
EDIT:
For now I will have my stock LCAs, later I will buy BLOX. Now I found that sways should fit fine....but I could use someones comformation
tnx
Modified by n1ghthawk at 6:00 AM 11/23/2006
Old Nov 23, 2006 | 03:23 AM
broketuner-Sol_Si's Avatar
Default Re: ITR sway bars (n1ghthawk)
you'll be fine for the rear, but I think you may need the integra endlinks and possibly the front LCAs too.
Old Nov 23, 2006 | 04:29 AM
pdiggitydogg's Avatar
no, you need em1 endlinks
I dont think you can bolt the front sway onto the civic
you WILL need a reinforcement kit with the swaybar, or you'll tear the subframe.
I highly recommend A-Spec Racing's kit.
Old Nov 23, 2006 | 05:34 AM
cambopheonix56's Avatar
Default Re: (pdiggitydogg)
Use the ASR kit. I have that setup and its wonderful.
Old Nov 23, 2006 | 05:35 AM
n1ghthawk's Avatar
Front wont fit?
Could somebody provide part numbers for EK9 sway bars? that should fit, right?
Old Nov 23, 2006 | 06:04 AM
Default Re: (n1ghthawk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1ghthawk &raquo;</TD></TR><TR><TD CLASS="quote">Front wont fit?
Could somebody provide part numbers for EK9 sway bars? that should fit, right?</TD></TR></TABLE>
Use an em1 one. Its like 23mm or something like that.
Old Nov 23, 2006 | 06:19 AM
just use the stock front ex bar...its fine
to use the em1 bar, you have to use em1 front lca's...its just a waste
Old Nov 23, 2006 | 10:51 AM
BlueIntegraBoy's Avatar
The believe the stock front is 22mm. It should be fine, you will need to test your car out first before bumping it up to 24mm (ITR) or 26mm (Si).
Old Nov 23, 2006 | 10:54 AM
Eran's Avatar
HT White Ops
Or, you could get the Suspension Techniques front and rear for $300.
Old Nov 23, 2006 | 11:11 AM
Mr. Em1's Avatar
the em1 front is 26mm front sway, its a pretty good size, and for the rear use some kind of rear subframe reinforcement brace, the 22mm type r rear sway bar is nearly 700 percent stiffer than the 13mm stock si bar, ASR makes a really nice piece that bolts on pretty easily and looks great Imho. The rear itr makes for a great upgrade making the car very neutral and predicatable.
recaroem2
Honda Civic (2001 - 2005)
Oct 12, 2007 07:18 PM
BLCK97EKCOUPE
Jun 7, 2007 07:42 PM
n.e.coupe
May 15, 2006 02:45 PM
AlienKrOZ
Oct 7, 2004 12:35 PM
DaNish
22
Aug 18, 2003 06:29 AM
