H22 EG Bottem end torque issue!
Old Nov 22, 2006 | 10:33 PM
dc2vu's Avatar
Default H22 EG Bottem end torque issue!
Sorry to make another thread about this but I just wasnt getting many replies in the Hybrid forum. Maybe I can get some help here.
https://honda-tech.com/zerothread?id=1817285
Mods, if you feel like this thread shouldn't be here please by all means feel free to remove this thread.
Thanks for your time whoever reads this.
Old Nov 23, 2006 | 03:50 AM
2point2's Avatar
Default Re: H22 EG Bottem end torque issue! (dc2vu)
IABs will not make or break your low end torque in a lightweight Civic. Have you even set your base timing?
What have you tried besides wasting your time with the IABs? Was the timing belt changed recently?
Old Nov 23, 2006 | 08:23 AM
dc2vu's Avatar
Default Re: H22 EG Bottem end torque issue! (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">IABs will not make or break your low end torque in a lightweight Civic. Have you even set your base timing?
What have you tried besides wasting your time with the IABs? Was the timing belt changed recently?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1434272
Timing is dead stock. Nothing was changed from when it was removed from the JDM halfcut. I have checked timing on the flywheel and its set at 15 degress (stock).
Old Nov 23, 2006 | 01:09 PM
dc2vu's Avatar
H22 woes...alternater took a poop today....turned on my headlights and it popped both of em...alternater + 60 bucks for some jdm h4h headlight bulbs
Old Nov 23, 2006 | 08:30 PM
iwubmybb4's Avatar
Default Re: (dc2vu)
that ******* sucks.
Old Nov 23, 2006 | 09:24 PM
dc2vu's Avatar
I decided to pull the valve cover off and take a look at the timing marks on the cam gears. At TDC both UP arrows are pointing up. So, yes, timing is on.
00trdtaco
Feb 27, 2008 05:44 PM
turbo boost
11
Apr 20, 2005 12:55 PM
vtec69
Aug 25, 2004 12:45 PM
SymphonyX
Mar 18, 2003 08:35 PM
dirtySOHC's
Feb 14, 2002 01:07 PM
