HELP! Head Gasket Set Question
UPDATED WITH NEW PIC AND MEASUREMENTS ONLY A FEW MORE THINGS TO FIGURE OUT!
Can someone please tell me what the numbered items in the picutre are? This is an OEM Ishino Cylinder Head Gasket Set for a Z6. there was no parts list with the package.
Ive labelled as much as I could so I need some help with the rest.
1. Thermostat Gasket
2. Oil Catchcan PCV grommet
3. O-rings for pipe between thermostat and water pump
4. Oil Filler Cap Gasket
5.
6.
7.
8. Fast Idle Vavle Gasket
9.
10.
11. Oil Jet Gasket?
12. Dizzy O-ring
13. EACV Gasket
14. Throttle Body Gasket
Modified by funkified at 8:48 AM 11/23/2006
Modified by funkified at 9:00 AM 11/23/2006
Modified by funkified at 9:25 AM 11/23/2006
Modified by funkified at 9:30 AM 11/23/2006
Modified by funkified at 9:39 AM 11/23/2006
Modified by funkified at 9:43 AM 11/23/2006
Modified by funkified at 10:19 AM 11/23/2006
Modified by funkified at 8:40 AM 11/24/2006
Modified by funkified at 2:28 PM 11/24/2006
Modified by funkified at 2:30 PM 11/24/2006
5.
6.
7.
9.
10.
11. Oil Jet Gasket?
12. Dizzy O-ring
13. EACV Gasket
13. EACV gasket
14. Is that the gasket the goes between the intake and the butterfly(what ever that is called)??????
I would guess that a gaskets is the dizzy o-ring.(maybe 12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">Why does the head gasket set not come with a headgasket? </TD></TR></TABLE>
lol it did, no sense in taking up valuble picture space when i kno what it is
if you can measure 9,10, and 11, I'm pretty sure they have something to do with the fuel rail and fuel-pressure regulator:
http://www.hondapartsdeals.com...5.gif
ya ill def measure those when i get home, i did this up last night and was too lazy to measure the small ones. thanks for all the help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant »</TD></TR><TR><TD CLASS="quote">if you can measure 9,10, and 11, I'm pretty sure they have something to do with the fuel rail and fuel-pressure regulator:
hey what manual are those pics from?
11. might also be the oil jet gasket.
The pic is from hondapartsdeals.com. All the numbers have part descriptions, but the link to the site is not transferrable (https://) so you have to dig down to it.
http://www.hondapartsdeals.com/honda_parts.php
morning bump! updated pic w/ new measurements! thanks again for all the help!
also heres a pic of that cone shaped piece
(h)29mm x (w)22mm
Modified by funkified at 9:05 AM 11/24/2006
(h)29mm x (w)22mm
looks like the rubber insert in the oil catchcan on the back of the block. The piece that goes in first, then the pcv valve slides inside this piece then hooks to a hose that comes up through the manifold that leads to the plenum to vent the crankcase.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMkrew_1 »</TD></TR><TR><TD CLASS="quote">looks like the rubber insert in the oil catchcan on the back of the block. The piece that goes in first, then the pcv valve slides inside this piece then hooks to a hose that comes up through the manifold that leads to the plenum to vent the crankcase.</TD></TR></TABLE>
thats the little black box that sits in front of the water pipe, and underneath the intake mani right?
Yes. There is a black box on the back of the engine that will have that grommet with a plastic tube for the hose to connect to that will lead to pvc valve on top of intake manifold.
HondaHeddie
Nov 8, 2006 01:42 PM
