fuel pressure
Old May 8, 2002 | 10:38 PM
95integrags-r's Avatar
Default fuel pressure
with my mods(in signiture) what should my fuel pressure be set at?? I have it at 40 right now.
Old May 8, 2002 | 11:19 PM
Default Re: fuel pressure (95integrags-r)
no onE??????
Old May 9, 2002 | 06:15 AM
88_SC_CRX_Si's Avatar
New User
The color of your plugs, will tell you where your fuel pressure should be at. Get some Anti-Seize to put on them. That way you can pull the plugs, when the engine is hot, to check them without pulling the thread(s) out, along with the plug(s). Should be around a light tan in color. Try not to let it idle, after making a WOT run if possiable... Otherwise the plugs statts cleaning themsevles, giving you a false reading.
[Modified by 88_SC_CRX_Si, 7:22 AM 5/9/2002]
Old May 9, 2002 | 07:14 AM
Doctor CorteZ's Avatar
DYNO !!!!!!!!!!!!!
when will people learn?
DYNO !!!!!!!!!!!!!
Old May 9, 2002 | 09:52 AM
New User
Default Re: fuel pressure (Doctor CorteZ)
Yes you are right... However, not all the peeps have the means or a location to get to one... But you have to do, what you have do. hehehe
Old May 9, 2002 | 02:14 PM
Default Re: fuel pressure (88_SC_CRX_Si)
i havent dynoed yet , thus I'm running STOCK 42 psi
duf2570
Sep 8, 2013 06:37 PM
Silvertc
Sep 23, 2010 09:49 AM
RedRacerCivic
Oct 29, 2004 06:30 AM
PM-Performance
Jan 30, 2004 01:16 AM
