did compression test
1995 GSR w/ 90k miles
1st compression test without oil being added to the cylinders.
cyl 1- 175
cyl 2- 160
cyl 3- 160
cyl 4- 165
2nd compression test with a cap of oil added to the cylinders.
cyl 1- 190
cyl 2- 185
cyl 3- 195
cyl 4- 190
any good?
question: after the oil being added to the cylinder and starting the car up is it supose to smoke out the exhaust and smell like oil is burning?
cyl 1- 175
cyl 2- 160
cyl 3- 160
cyl 4- 165
cyl 1- 190
cyl 2- 185
cyl 3- 195
cyl 4- 190
any good?
Ha, of course it's going to smoke, it's burning all the oil you just poured into the cylinders. From your results it looks like your rings have some wear, does the car smoke at all? (excluding when you oil it yourself)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD »</TD></TR><TR><TD CLASS="quote">Ha, of course it's going to smoke, it's burning all the oil you just poured into the cylinders. From your results it looks like your rings have some wear, does the car smoke at all? (excluding when you oil it yourself)</TD></TR></TABLE>
with my exhaust silencer off grey and with the silencer on white sorta.
If your rings are going it's going to be blue smoke which is oil. Grey? that might be blue. White is coolant but it smells real sweet so if you're burning coolant you would definitely know. Numbers sound low for the miles. Sounds like that motor has been abused a bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD »</TD></TR><TR><TD CLASS="quote">If your rings are going it's going to be blue smoke which is oil. Grey? that might be blue. White is coolant but it smells real sweet so if you're burning coolant you would definitely know. Numbers sound low for the miles. Sounds like that motor has been abused a bit.</TD></TR></TABLE>
its not blue. i have 20/20 vision...its grey i always let my friends drive my car and when they hit vtec once in a while it comes out. im assuming grey is from the white/black smoke mixing together... abused? yeap through the moutain(s) every other day in vtec for about 10 minutes straight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluestreak_1 »</TD></TR><TR><TD CLASS="quote">That could be excess fuel as well. Has the car been tuned any at all?</TD></TR></TABLE>
nope. i also heard white smoke could be some fuel burning.....correct me if im wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD »</TD></TR><TR><TD CLASS="quote">Fuel is black, but it might look grey... Is there a lot of carbon on your muffler tip? that's fuel. </TD></TR></TABLE>
i dont know i have buddyclub spec 2 exhaust so it doesnt have a tip really like a stock exhaust, but inside the exhaust its all black.
Fat Chick Magnet
Nov 22, 2006 09:52 PM
