Sanding Touch Up Paint...
Old Nov 22, 2006 | 06:07 PM
JDM Like Whoa's Avatar
Default Sanding Touch Up Paint...
I applied some touch up paint to spots that needed it and I dont really like how it sticks out. Can I possibly wetsand over it to remove the excess with like 2000 then 3000 then buff it to perfection or am I stuck with the buldge?
Old Nov 22, 2006 | 06:12 PM
Fresh'86's Avatar
Default Re: Sanding Touch Up Paint... (ImportRacr05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportRacr05 &raquo;</TD></TR><TR><TD CLASS="quote">I applied some touch up paint to spots that needed it and I dont really like how it sticks out. Can I possibly wetsand over it to remove the excess with like 2000 then 3000 then buff it to perfection or am I stuck with the buldge? </TD></TR></TABLE>
No, it's better if you do sand it. You will need clear coat though. Here is a usefull thread I wrote up that you should look at before attempting anything:
http://forums.clubel.ca/showthread.php?t=23738
Good luck!
Old Nov 22, 2006 | 06:19 PM
Wow, thats a huge writeup. What kinda clearcoat would I benefit from?
Old Nov 24, 2006 | 06:57 AM
Fresh'86's Avatar
Default Re: (ImportRacr05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportRacr05 &raquo;</TD></TR><TR><TD CLASS="quote">Wow, thats a huge writeup. What kinda clearcoat would I benefit from? </TD></TR></TABLE>
Well I never had a problem with any clearcoat, and I've used the Duplicolor ones you can find at the big automotive department stores(pep boys in the states probably? Canadian Tire in Canada). If it still looks dull, sand it with 1500grit, then 2000grit(wet sand of course. An easy way to wetsand if to have a bucket of hot water with you, and just dip the sand paper in every couple of seconds and keep it wet) and then use an orbital sander and rubbing compound. Once that is done, use some wax and you're good to go.
juli_wing
Paint and Body
Dec 28, 2007 03:47 PM
Inextricabledrvr
Oct 20, 2007 03:27 AM
JDM RHD eg6
13
Nov 20, 2006 10:08 AM
huge230
May 21, 2006 12:03 PM
Street Ghost
17
Dec 31, 2003 10:47 AM
