Hesitation between 1500-2800 rpm
Old Nov 22, 2006 | 04:33 PM
mtnwkr's Avatar
Default Hesitation between 1500-2800 rpm
My new cd5 has the classic signs of a clogged egr..Hesitation between 1500-2800 rpm... Well, I cleaned that well today(it really wasnt that bad), also changed plugs, cap and rotor. Anything else that might be causing this hesitation? Wires maybe? they look fine.. It has 138,000 miles and its a 5 speed...thanks.
Old Nov 22, 2006 | 04:44 PM
YeuEmMaiMai's Avatar
did you clean egr valve and intake egr passages?
Old Nov 22, 2006 | 05:00 PM
mtnwkr's Avatar
Default Re: (YeuEmMaiMai)
this is what I did.. http://home.comcast.net/~em-engineering/T2T013.pdf
Is there more to it than this?
Old Nov 22, 2006 | 05:06 PM
jb.'s Avatar
jb.
Default Re: (mtnwkr)
now that you mention it, i get the same thing in second gear of my automatic. I just changed the wires, rotor, cap, and plugs (iridium, which may have caused a drop in mileage???)
Old Nov 22, 2006 | 05:40 PM
yeah that's it.
run some FI and intake cleaner through the engine as well
Old Nov 22, 2006 | 05:49 PM
mtnwkr's Avatar
The kind you dump in the gas tank? Done a few bottles of that as well....
Old Nov 22, 2006 | 05:58 PM
Homesickelian's Avatar
Try the lucas lube stuff for the fuel system.
http://www.lucasoil.com/products/index.sd
It's a little different from most fuel cleaning products and people that know cars a little better seem to like it. You may not need it but listen to YeuEmMaiMai.
Old Nov 23, 2006 | 04:06 AM
might want to use bottled stuff that they introduce through vaccum line on intake.......
Old Nov 23, 2006 | 01:14 PM
mtnwkr's Avatar
Like seafoam? I was thinking about doing the seafoam in the intake and the gas tank.
Old Nov 26, 2006 | 04:53 PM
jb.'s Avatar
jb.
any developments??
Old Nov 26, 2006 | 05:08 PM
loup05's Avatar
Default Re: (jb.)
how do i remve the fuel rail? all the small hoses are hard to take off i dont want to damage them. whats the easiest way to remove them
Old Nov 30, 2006 | 12:31 PM
jb.'s Avatar
jb.
Default Re: (loup05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loup05 &raquo;</TD></TR><TR><TD CLASS="quote">how do i remve the fuel rail? all the small hoses are hard to take off i dont want to damage them. whats the easiest way to remove them</TD></TR></TABLE>
i dont know
Old Nov 30, 2006 | 01:39 PM
just twist them off and kinda push also on the ends. If its stuck bad its ok to insert something that isn't sharp and kinda pry it off... they are pretty flexible.
Old Dec 7, 2006 | 06:10 AM
jb.'s Avatar
jb.
Default Re: Hesitation between 1500-2800 rpm (mtnwkr)
when cleaning your egr ports ect, did you have to change any gaskets?
Old Dec 8, 2006 | 07:22 AM
jb.'s Avatar
jb.
Default Re: Hesitation between 1500-2800 rpm (jb.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jb. &raquo;</TD></TR><TR><TD CLASS="quote">when cleaning your egr ports ect, did you have to change any gaskets?</TD></TR></TABLE>
im going to try to do it this weekend, anyone know?
Old Dec 8, 2006 | 06:58 PM
loup05's Avatar
there really isnt any gaskets to change. theres one but its like hard plastic and it should be fine
Old Dec 9, 2006 | 01:58 AM
mtnwkr's Avatar
Default Re: Hesitation between 1500-2800 rpm (loup05)
Change the o-rings on the end of the injectors before putting them back in the fuel rail. I got all 4 from the dealer for like 12 bucks.
I cleaned my ports and still have the same issues. Also seafoamed my engine, ran lucas lube through the gas tank, and cleaned the manifold.. Im thinking of blocking off the egr with a plate to see if that solves my problems so I can narrow it down to the egr system.
Old Dec 11, 2006 | 12:55 PM
loup05's Avatar
i think the problem with my car is that the egr is stuck open half ways. i disconected the lift solenoid but i still have the hesitation i might just buy a new egr valve
Old Dec 11, 2006 | 02:59 PM
mtnwkr's Avatar
So would disconecting the lift solenoid give the same results as the port blocking plate?
Old Dec 15, 2006 | 06:04 PM
loup05's Avatar
im not sure what u mean. technically the egr valve should not open at all if the lift solenoid is disconected because it is electricly (spelling?) controlled. So if u disconect the lift soleoid and ur problem goes away then i would suppose u have a bad egr valve
ld1985
Nov 18, 2009 12:10 PM
nine23
Jan 18, 2009 01:33 PM
refman102
Feb 12, 2007 04:23 AM
jb.
Nov 30, 2006 01:36 PM
aznmc16
Jul 5, 2002 01:12 AM
