what fuel components do i need?
Walboro 255 in tank or a similar pump of your choice and some injectors that are sufficient for your power goals (and a way of controlling them). Pretty much everything else will be fine.
Or if you want to upgrade further, grab a pressure regulator and a rail.
550's probably...
nothin wrong with buyin more expensive bigger ones.. you can always run them at a lower duty cycle...
its better to have lots of fuel instead of not enough
walbro 255 pump and some injectors is all you need...
What year is the Civic?
If 96+ you are going to want:
- Conversion Harness to convert to OBD1
- OBD1 ECU
- Larger Injectors (440cc would be enough for 8-10 psi)
- Fuel Pump is certainly a good idea
After that, all you need is tuning...tuner directory is at the top of this forum!
- OBD1 ECU
deucedeuceEK
Jun 2, 2007 04:33 AM
jeremy.
Sep 29, 2003 05:35 PM
