trouble bleeding the clutch
Old Nov 22, 2006 | 03:17 PM
Doeboy's Avatar
Default trouble bleeding the clutch
i just recently swaped a ls tranny into my b20 hatch. i went to bleed the clutch and it wont pull any fluid through the line. what should i do? any input will help thanks.
Old Nov 22, 2006 | 04:07 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: trouble bleeding the clutch (Doeboy)
did you check the clutch master?? any leaks
Old Nov 22, 2006 | 04:14 PM
JDM94EG28's Avatar
Default Re: trouble bleeding the clutch (DBL)
try opeing the vavle on the slave cyelndor and see if any fluid making it to the slave
Old Nov 22, 2006 | 04:22 PM
Doeboy's Avatar
i looked at the master cylinder, no leaks. and i also took out the bleeder valve and there is nothing coming out. the clutch pedal is pretty much dead. it just springs up and down when you pull or push.
Old Nov 22, 2006 | 05:08 PM
mrlegoman's Avatar
Default Re: (Doeboy)
I replaced both my master and slave. I had to pump the living crap out of it till it started bleeding. I just left the bleeder open and pumped the clutch by hand for about 10 minutes. It finally started sucking fluid.
Old Nov 22, 2006 | 05:35 PM
JDM94EG28's Avatar
Default Re: (mrlegoman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman &raquo;</TD></TR><TR><TD CLASS="quote">I replaced both my master and slave. I had to pump the living crap out of it till it started bleeding. I just left the bleeder open and pumped the clutch by hand for about 10 minutes. It finally started sucking fluid. </TD></TR></TABLE>
same thing i did on of my boys car that couldnt get his clutch going..
Old Nov 22, 2006 | 05:59 PM
Doeboy's Avatar
im going to go the the store and get a vacum type pump to pump the fluid thru the line. i hope it works, i dont want to pump that **** for 10 mins.
Steviebix33
Aug 14, 2011 07:43 PM
delsolsi193
11
Apr 7, 2009 09:46 AM
Paluce
Jun 1, 2007 12:15 PM
jdm_lude
Jul 14, 2003 01:25 PM
safe driver
Nov 14, 2001 03:23 PM
