Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
BDL throttle bodies, fuel rails, cam gears and seals
Old Nov 22, 2006 | 03:07 PM
earl's Avatar
Default BDL throttle bodies, fuel rails, cam gears and seals
Laskey Racing is proud to offer these high end products at a cost to suit everyone. http://www.laskeyracing.com/shop/externals.htm
IM Ninesecrx for any questions...
Throttle Bodies
Engineered to deliver greater throttle response and increased air flow, as a
leader in aftermarket performance BDL has added a new member to it's family
of elite performance products. The BDL throttle body is CnC machined from
billet to o.e.m. fitment and accepts stock sensors and vacuum fittings.
Includes double sealed bearings. Throttle bodies are available in 68/66, 70
and 74/72mm bores for increased flow on mild to full race applications.
Guaranteed not to stick, your prayers have been answered with applications
for most hondas/acuras.
68/66 mm tapered throttle body B Series Engines $280 Shipped
70/70 mm throttle body B Series Engines $299 Shipped
74/72 mm tapered throttle body B Series Engines $329 Shipped
Various RSX Type S K20 $399 All Sizes
Various Civic Si K20 $399 All Sizes
Various 1.6 SOHC $295 All Sizes
Various Prelude $299 All Sizes
Various S2000 $315 All Sizes
K series
B series
Cam Gears
These new innovative cam gears adhere to strict RMA standards, meaning they
are designed with a special tool so that each tooth is precisely matched to
the OEM timing belt. Each gear is made from billet, utilizes aircraft grade
1/4" 12 point bolts with washers to ensure no slippage under any
circumstances. The gear is then anodized with an exclusive bronze flavor and
then finished off with a laser etching to insure they are accurately aligned
with top dead center. Nothing even come close to the technology BDL has
invested in these remarkable cam gears.
Adjustable Cam Gears B series DOHC $185 pair Shipped
Adjustable Cam Gears H22 series DOHC $185 pair Shipped
Adjustable Cam Gears H23 series DOHC $185 pair Shipped
Adjustable Cam Gears D series SOHC $99 ea Shipped
Adjustable Cam Gears Other Makes Call Shipped
Fuel Rails
BDL has released a true bolt on fuel rail for a street car which has only
improved over time. Now with it's latest release, incorporating a -6
oulet/inlet in the center of the rail to allow for a return or additional
point of entry for increased fuel flow it is still the best fuel rail on the
market. Enhancements include a larger 3/4 inch center bore, accommodating a
-8. allowing 80% more fuel flow than most competitors rails. The new rail
includes an extra port for a remote mount fuel pressure gauge, mounting
hardware, replacement 0-rings, crush washers, extensive installation
instructions and the satisfaction you bought the highest quality aftermarket
product available for your vehicle.
Billet Fuel Rail B and D Series $115 Shipped Clear, Blue, Bronze, Red, Titanium, Black
Billet Fuel Rail S2000 $170 Shipped Clear, Blue, Bronze, Red, Titanium, Black
Billet Fuel Rail RSX-S or Civic Si $165 Shipped Clear, Blue, Bronze, Red, Titanium, Black
Billet Fuel Rail Prelude $115 Shipped Clear, Blue, Bronze, Red, Titanium, Black
Billet Fuel Rail Other Makes Call
Cam Seals
Constructed from 6061 aluminum, the pro seal solves the dirty little
problems Honda/Acura dohc motors experience after years of service. The oem
seal tends to crack, resulting in annoying oil leakage. The pro seal is the
stylish solution, incorporating a dual viton o-ring design that is
guaranteed to seal. (the secret is in the 2 o-rings) shhhh. exceeds oem
standards and is available in 5 colors; polish, blue, bronze, red and
titanium, each etched with the one and only BDL trademark.
Most Honda Engines Various $20 $7 for shipping (any volume)
Modified by earl at 8:18 PM 5/1/2007
Old Nov 26, 2006 | 01:19 AM
STREETWERKZ's Avatar
Default Re: BDL throttle bodies, fuel rails, cam gears and seals (earl)
gotta get me some.
Old Nov 27, 2006 | 03:58 PM
nuckingfuts's Avatar
Default Re: BDL throttle bodies, fuel rails, cam gears and seals (STREETWERKZ)
looking for BDL Rsx fuel rail and Civic si Ep3 alternator pulley. Let me know availability on colors too
Old Dec 1, 2006 | 03:55 PM
Sprockets's Avatar
I know that the old STR cam gears only came in bronze with 1/4" bolts, but the new BDLs have ARP 5/16" bolts and are available in bronze, titanium, and clear. The picture below (edit...now above) looks like the new style, but the item description is different. Which ones are you selling? Thanks!
Old Dec 27, 2006 | 01:37 PM
ninesecrx's Avatar
Default Re: BDL throttle bodies, fuel rails, cam gears and seals (Sprockets)
All of the BDL gears we sell come with the new larger ARP bolts.
Old Dec 27, 2006 | 08:24 PM
titan2nv's Avatar
do the throttle bodies come with tps. i read an article on honda tunning about bdl throttle bodies and they said that they put a boss tps. is this true.
Old Dec 28, 2006 | 01:08 AM
ninesecrx's Avatar
Default Re: (PROJEK98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PROJEK98 &raquo;</TD></TR><TR><TD CLASS="quote">do the throttle bodies come with tps. i read an article on honda tunning about bdl throttle bodies and they said that they put a boss tps. is this true.</TD></TR></TABLE>
The BDL tb retains the factory tps and does not come with one.
Old Feb 10, 2007 | 04:27 PM
pearlteg's Avatar
Default Re: (ninesecrx)
i want to get or pick up a fuel rail asap
Old Feb 21, 2007 | 06:00 AM
stockbee's Avatar
bump
Old Feb 24, 2007 | 01:13 AM
Vtec_SIR's Avatar
how much would be a fuel rail for b-series and 2 cam seal shipped to vancouver bc canada V5P3B5
Old Feb 24, 2007 | 01:38 PM
turboedc2's Avatar
Default Re: (Vtec_SIR)
DO YOU GUYS HAVE A TRAIGHT 74MM INSTEAD OF TAPERED?
Old Feb 25, 2007 | 09:41 PM
NJcoupe's Avatar
Default Re: (turboedc2)
rip earl
Old Mar 26, 2007 | 11:33 AM
ninesecrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboedc2 &raquo;</TD></TR><TR><TD CLASS="quote">DO YOU GUYS HAVE A TRAIGHT 74MM INSTEAD OF TAPERED?</TD></TR></TABLE>
No, BDL only makes a tapper 74mm.
Old Mar 31, 2007 | 06:51 PM
adhana2's Avatar
Default Re: (idriveacoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveacoupe. &raquo;</TD></TR><TR><TD CLASS="quote"> rip earl</TD></TR></TABLE>
Old Apr 9, 2007 | 07:03 AM
97crxdelsol's Avatar
can u run the fitv on the bdl tbs?
Old Apr 10, 2007 | 02:47 PM
ninesecrx's Avatar
Default Re: BDL throttle bodies, fuel rails, cam gears and seals (97crxdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97crxdelsol &raquo;</TD></TR><TR><TD CLASS="quote">can u run the fitv on the bdl tbs?</TD></TR></TABLE>
They only have ports for stock tps and map sensor/ vacum. Plus a idle air adjust screw.
Old May 10, 2007 | 06:13 PM
ninesecrx's Avatar
Default Re: BDL throttle bodies, fuel rails, cam gears and seals (ninesecrx)
Old May 24, 2007 | 06:22 PM
ninesecrx's Avatar
Old Jun 13, 2007 | 11:36 PM
ninesecrx's Avatar
Old Jun 15, 2007 | 12:07 PM
drew22mader's Avatar
i seen it said that the fuel rail is for the D series engines, can u tell me if this will fit on my D17 motor?
Old Jun 15, 2007 | 07:23 PM
ninesecrx's Avatar
Default Re: BDL throttle bodies, fuel rails, cam gears and seals (drew22mader)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew22mader &raquo;</TD></TR><TR><TD CLASS="quote">i seen it said that the fuel rail is for the D series engines, can u tell me if this will fit on my D17 motor?</TD></TR></TABLE>
I do not know as I have never had anyone buy a rail for that engine.
Old Jun 16, 2007 | 09:58 PM
VIS250P's Avatar
Do u have B series Black BDL Fuel Rail? IF yes, please let me know...
Old Jun 22, 2007 | 09:14 AM
94gsr_teg's Avatar
you have a clear bdl fuel rail for the b series, LMK
Old Jun 22, 2007 | 11:43 AM
ninesecrx's Avatar
Default Re: BDL throttle bodies, fuel rails, cam gears and seals (94gsr_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr_teg &raquo;</TD></TR><TR><TD CLASS="quote">you have a clear bdl fuel rail for the b series, LMK</TD></TR></TABLE>
In stock...
Old Jun 24, 2007 | 11:44 AM
VIS250P's Avatar
Default Re: BDL throttle bodies, fuel rails, cam gears and seals (py)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py &raquo;</TD></TR><TR><TD CLASS="quote">Do u have B series Black BDL Fuel Rail? IF yes, please let me know...</TD></TR></TABLE>
No answer from you? I need to know soon!!
