Problems associated with powdercoating
Old Nov 22, 2006 | 03:00 PM
PrinceAli132's Avatar
Default Problems associated with powdercoating
I am planning on powdercoating my calipers, caliper brackets, rear lower control arm, front lower control arm, and possibly the rear trailing arm and front spindle. I was just wondering if there might be any problems. I have searced around and found out that powdercoating weakens any forged metal, through annealing (sp). Has anyone powdercoated these parts before, and should I be worried at all?
Ali
Old Nov 22, 2006 | 03:02 PM
Tadehi's Avatar
Schumacher '10 WDC
Default Re: Problems associated with powdercoating (PrinceAli132)
If anything it helps make it a little stronger. It will protect the parts from the elements. Just dont use to much.
Old Nov 22, 2006 | 03:13 PM
white rocket's Avatar
There is a powdercoating sponsor in the forums. TRDcoatings or something like that. Try PM'ing or emailing him, he may know.
Old Nov 22, 2006 | 03:23 PM
Amped's Avatar
Default Re: (white rocket)
You will have to completly strip everthing to bare metal, They "bake the paint on". All bushings and the pistons in the calipers need to be removed. It would look nice if you did do it though. I was goin to do it myself. Good amount of work and Some money.
Old Nov 22, 2006 | 03:30 PM
BlueR's Avatar
Default Re: (Amped)
annealing occurs @ temps well above 700c
the heating process associated with powdercoating will see temps of about 200c
so its a relatively harmless process
Old Nov 22, 2006 | 03:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">There is a powdercoating sponsor in the forums. TRDcoatings or something like that. Try PM'ing or emailing him, he may know.</TD></TR></TABLE>
Thanks, i'll pm him.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Amped &raquo;</TD></TR><TR><TD CLASS="quote">You will have to completly strip everthing to bare metal, They "bake the paint on". All bushings and the pistons in the calipers need to be removed. It would look nice if you did do it though. I was goin to do it myself. Good amount of work and Some money.</TD></TR></TABLE>
Im not to worried about stripping everything because I plan on replacing all bushings and rebuilding the calipers.
Thanks for the replies
Ali
Old Nov 22, 2006 | 03:33 PM
Default Re: (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">annealing occurs @ temps well above 700c
so its a relatively harmless process</TD></TR></TABLE>
Thanks for clearing that up.
Ali
Old Nov 22, 2006 | 03:36 PM
Amped's Avatar
Default Re: (PrinceAli132)
I found a company that powder coats there calipers. They use OE calipers not a bad price either. But if your comfortable rebuilding thats respectable. Have you ever rebuilt a Honda caliper?
Old Nov 22, 2006 | 03:45 PM
Default Re: (Amped)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Amped &raquo;</TD></TR><TR><TD CLASS="quote">I found a company that powder coats there calipers. They use OE calipers not a bad price either. But if your comfortable rebuilding thats respectable. Have you ever rebuilt a Honda caliper?</TD></TR></TABLE>
I have not rebuilt calipers yet, but figured I might try. I have searched around and it does not seem to bad to do. If you could send me the link to the place your referring to.
Edit - I pm'd TRD-Coating and asked him and sent him a link to this thread, if he doesn't post a reply in here i'll post what his response to me.
Ali
Old Nov 22, 2006 | 03:52 PM
waddy41's Avatar
good luck...show us some pics along the way
this seems like an interesting project
Old Nov 22, 2006 | 04:06 PM
Default Re: (waddy41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waddy41 &raquo;</TD></TR><TR><TD CLASS="quote">good luck...show us some pics along the way
this seems like an interesting project</TD></TR></TABLE>
Keep an eye out for my build thread which can be found in my sig. But it will be a slow build so it might be a while.
Ali
AZ-Accord
Jan 9, 2013 05:23 PM
teaks92hb
12
Nov 22, 2011 11:22 AM
kasperxtcy
Suspension & Brakes
Mar 24, 2010 09:14 AM
lsnidex
Suspension & Brakes
Aug 9, 2009 01:23 PM
friday86
Oct 19, 2006 04:37 PM
