H22 turbo, front mount??
Wondering if anyone has any experiance with removing totally the front motor mount thats on the crossmember from their accord or prelude. I know thats how they do it with the Hasport mounts for the civics, with a heavy duty rear mount. Wondering if the same principle can be used on the Accord for more of a choice for a manifold.
any thoughts would be appreciated, thanks
if you sure up the other 3 mounts you might be ok. when i did my setup, i just ground the crossmember alittle and the engine alittle and i git a 3 inch down pipe in. I then modded the rubber front mount alittle, i think with inserts for the reaming 3 you would be fine. or just build around it.
OutlawCL
Sep 11, 2004 01:20 PM
