MAP sensor question
Old Nov 22, 2006 | 11:39 AM
Del Sol on Steroids's Avatar
Default MAP sensor question
I'm having problems with a MAp sensor code. I have checked the wiring and the wiring is good. So this leaves me with the options of bad ECu tuning or Map sensor. Can I replace my map sensor with any OBD1 Map sensor?, or does i has to from an B18C1?
Old Nov 22, 2006 | 11:52 AM
fmrprojects's Avatar
Default Re: MAP sensor question (Del Sol on Steroids)
all map sensors are the same , obd1 and obd2. are you sure the tps and map sensor plug are not switched?
Old Nov 22, 2006 | 12:50 PM
Default Re: MAP sensor question (fmrprojects)
The MAP sensor plug is receving the correct amount of voltage, it is also receving it at ecu through wiring. The wiring is confirmed that the wiring is working, We have ome to the conclusion that is the map sensr is just not receiving pressure at vteec or load on the engine. But is the map sensor or the ecu for sure. That I know.
GearheadzAuto
Nov 15, 2007 08:05 AM
Del Sol on Steroids
Nov 26, 2006 11:54 AM
Boosted Chemist
Jun 15, 2005 02:30 PM
