door panel
what exactly are you having trouble with? when i put them in i take the little mirror covers out and slip the panel over the top first. then i pull it down a little, pop the mirror cover back in, and push the panel clips into the door.
the tricky part on mine is the top. You have to make sure the top is aligned in in place before you can pop/hit the rest of the panel into its clips back on the door
I am having trouble with this now. I can't get the top of the panel in place. I can the side next to the mirror to go down fine, but the back end along the top i can't get in at all. I am doing the same thing as the video on t-i shows, but it still won't go in.
Mike V. Dubs
May 19, 2008 08:31 PM
