91 accord ignition switch
I'm replaceing my girlfriends ignition swtich and I've ran into a problem. I've removed everything from the steering column. But I can't see any more screws or pins that are holding the switch in the houseing. Someone please help.
SRS components are located in this area, precautions, and procedures must follow before you perform any repairs. (if you have air bags, parachute etc)
are you replacing the whole ignition lock assembly?
no just a switch right ?
then
disconnect the battery negative cable
remove the steering column covers
insert the ignition key, and turn it to "0"
remove the 3 screws, and replace the electrical switch.
then
oh, here is whole ignition nine yard.
http://techauto.te.funpic.org/ignitionswitch.php
Modified by ujhonda at 10:24 AM 11/22/2006
jdmjosh1
Mar 31, 2010 03:32 PM
