Si: Revs into VTEC
When you rev past 5900 rpms on the Si, it kicks the VTEC on, a slight boost is felt...
When you change to the higher gear, the rpms drop below 5900 and therefore the car kicks back out of VTEC mode...then in another second you rev past 5900 again, and again the car kicks into VTEC mode.
Question: This quick, kick-in/out of VTEC have any bad effects on the engine? because VTEC turns on, turns off, turns on, turns off....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hazeburner »</TD></TR><TR><TD CLASS="quote">do you live on the moon?</TD></TR></TABLE>]
lmao
lmao
If I hit teh vtechk in forst gear and slamn teh 2send geaar my vtechk stays madd inengaged al teh way up 2 prbabply 5th gears. thee off/oN hasnt no hamrful aeafeects on the engines.
This guy is Borats' cousin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X »</TD></TR><TR><TD CLASS="quote">
the vtec is designed so that when your punchin ur pedal , it stays in high rpm so that it's not constantly turn on and off, which ***** up ur vtec, so make good use of it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkytoFlyS2k »</TD></TR><TR><TD CLASS="quote">the vtec is designed so that when your punchin ur pedal , it stays in high rpm so that it's not constantly turn on and off, which ***** up ur vtec, so make good use of it</TD></TR></TABLE>
Oh yeah? w0w, my vtak muz be real mest up y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron »</TD></TR><TR><TD CLASS="quote">LMAO!
dont shift at like 7k and it wont be a problem!
it's really not very hard to stay in vtec</TD></TR></TABLE>
I am glad everyone got a good laugh...reading it now, it does sound funny...maybe it didn't come out right.
I actually shift as close to possible to redline...but it still falls below VTEC line...I was just wondering if that was the norm ... or does everyone else stay above VTEC line?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaffee »</TD></TR><TR><TD CLASS="quote">I actually shift as close to possible to redline...but it still falls below VTEC line...I was just wondering if that was the norm ... or does everyone else stay above VTEC line?</TD></TR></TABLE>
If you are going out of Vtec, you are not shifting right. Redline is at 8200. So if you "shift around" redline, you do not know when you are shifting. As soon as the revs get to 8000 then you shift. It will not go out of Vtec. Practice makes perfect.
