Water not circulating - water pump?
Old Nov 22, 2006 | 01:09 AM
greasemonkee's Avatar
Default Water not circulating - water pump?
Over the past several days I noticed the heater wouldn't work unless I rev the crap out the engine. I went on a troubleshooting rampage and made sure nothing was blocked in the system. I even cranked it with the inlet line from the radiator in a bucket of water. After I changed the thermostat, put it all back together and see the same thing happening.
The radiator inlet hose is nearly too hot to touch and the radiator outlet hose is ambient temperature. The heater barely has any heat at all and it won't take anymore water.
I haven't noticed any severe corrosion on the coolant plumbing so I have a hard time thinking that part of the impeller came off. Anyone have any ideas?
Old Nov 24, 2006 | 01:22 PM
Default Re: Water not circulating - water pump? (greasemonkee)
Any ideas? There are no other symptoms. How often to water pump blades rust away?
q16racer
Honda S2000
Nov 14, 2011 10:58 AM
DumaDA
Jun 25, 2011 12:50 PM
mac_24_seven
Dec 29, 2008 01:27 AM
warlockip
Oct 6, 2008 09:02 AM
goowakjai
Aug 2, 2005 08:59 PM
