Intake manifolds which preforms the best.
I am looking to doing my d15b7 vtec build. I am really interested in the intake manifold. I guess the top three that I know of is the... Skunk2 / Edelbrock / D16Y8 Stock Manifold. Which do you guys think is the best. Which also have the best results..
SKUNK 2
Edelbrock 50 State legal
Stock Y8
SKUNK 2
Stock Y8
i heard that the all the aftermarket intake manifolds is the same **** as the y8 one so that be ur best choice nand probly the lowest price to pay.
im not sure if it completly true but thats what i heard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted-K24-EK »</TD></TR><TR><TD CLASS="quote">i heard that the all the aftermarket intake manifolds is the same **** as the y8 one so that be ur best choice nand probly the lowest price to pay.
im not sure if it completly true but thats what i heard</TD></TR></TABLE>
uhh all you have to do is look at the runners and tell that your statement isnt true.
Ive had both on my car, and I would def go with the Edelbrock. The Skunk2 requires you to up your fuel pressure, which means later down the road, fuel pump and regulator. The Skunk2 only gives you top end power...like on a highway...but you sacrifice low end punch. The Edelbock however gives you a very solid powerband all the way up to redline.. The Edelbrock is a very nice piece and ALL the sensors are used. Thats the one thing I hated about the Skunk2 was that the IACV is not used and left hanging in the bay, plus you have to "T" off a **** load of vacuum lines and some coolant lines... do what you want tho
well also i was reading up on ITB's (Indvidual Throttle Bodies). As in using the CBR 954 TB's, and mocking up a working manifold. I've even heard of a increase from a stock d1y8, with just the ITB's from the CBR 954. Bolted on and jumping from 120+ stock to 140...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpnucrx »</TD></TR><TR><TD CLASS="quote">Ive had both on my car, and I would def go with the Edelbrock. The Skunk2 requires you to up your fuel pressure, which means later down the road, fuel pump and regulator. The Skunk2 only gives you top end power...like on a highway...but you sacrifice low end punch. The Edelbock however gives you a very solid powerband all the way up to redline.. The Edelbrock is a very nice piece and ALL the sensors are used. Thats the one thing I hated about the Skunk2 was that the IACV is not used and left hanging in the bay, plus you have to "T" off a **** load of vacuum lines and some coolant lines... do what you want tho
uhh theres a place where i can mount an IACV on my skunk2 mani.
</TD></TR></TABLE>uhh theres a place where i can mount an IACV on my skunk2 mani.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAcivicEK »</TD></TR><TR><TD CLASS="quote">get an Si intake manifold. Makes a BIG difference. Skunk2, is the best outta those three.</TD></TR></TABLE>
si intake manifold? the si came with a b16...he has a d15b7. you cant bolt a b16 intake mani on a d15...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard »</TD></TR><TR><TD CLASS="quote">
si intake manifold? the si came with a b16...he has a d15b7. you cant bolt a b16 intake mani on a d15...</TD></TR></TABLE>
The 92-95 hatch has an SI model. Single cam D series
i have a skunk2 with a 68mm TB. i have no FITV. it idles higher (900 instead of 700)
and as far as performance...all i could tell is vtec is MUCH louder.
other than that...meh im gonna boost it
