LS with GSR tranny.
your ls would benift because the gsr trans has shorter gear ratio. But i wouldnt think it would be faster than a stock gsr. The gsr motor would still pull from it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboedDC »</TD></TR><TR><TD CLASS="quote">your ls would benift because the gsr trans has shorter gear ratio. But i wouldnt think it would be faster than a stock gsr. The gsr motor would still pull from it...</TD></TR></TABLE>
Its not for me, im asking this question for a friend i already have a gsr
Ive herd that it would make it faster than a gsr, i was looking to see if this information was true or flase. Thanks for the reply
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed »</TD></TR><TR><TD CLASS="quote">How much does a LS benfit with a GSR tranny? Would it make it faster than a stock GSR?</TD></TR></TABLE>i have a 93 Ls with a ys1 tranny in it came from a 2nd gen gsr and its great i reline first at about 37 so ya it benifits but the b18c1 will leave a b18a1 or b18b1 even with the tranny swap.
b16 tranny in an LS is REALLY nice if you like short gears. Espeacially with the torque of an LS. However, I'm not sure how you like being at 4.5k on the freeway going 75. GSR tranny in an LS is a nice compromise
I had a gsr tranny on the LS motor when i first purchased my car
after driving a stock LS compared to my car I could tell that the acceleration of the gsr tranny was much better, it felt stronger and not as slugish going through the rpm range
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-Lug »</TD></TR><TR><TD CLASS="quote">Espeacially with the torque of an LS. </TD></TR></TABLE>
Funny how I keep hearing about this "torque" the LS has but yet looking at real #s it would appear the GSR has just as much. Interesting I tell ya. Basically with a GSR tranny in both a LS and GSR, the LS will keep up, right until around 5500 where its power starts to die off and the GSR just keeps pulling.....ofcourse the LS will shift at 6800 and then the GSR will keep pulling some more...on up to 8k (ok, 7k and 8200 if you want to use fuel cutoff). GSR has just as much torque as the LS (in stock or near stock form) but has it over a much broader range (like 2500-8k vs 3500 to 5500 on the ls).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">
Funny how I keep hearing about this "torque" the LS has but yet looking at real #s it would appear the GSR has just as much. </TD></TR></TABLE>
Are you basing this statement from dyno numbers under WOT?? I'm talking about just regular steet driving. The LS has better low-end torque.
gsr tranny will help the ls but it still wont touch a gsr, the ls has better low end torque and the gsr has the high end power= the reason for ls/vtec,both have there good an bad sides but its basically whatever you what your car for
Are you basing this statement from dyno numbers under WOT?? I'm talking about just regular steet driving. The LS has better low-end torque.</TD></TR></TABLE>
i have a gsr and an ls; the gsr feels like it pulls better at low rpm because of the shorter gearing. i'm not sure why the ls is praised as having more torque than an gsr either; the gsr has more torque and shorter gearing.
Nutzurchin
Jul 16, 2003 01:26 AM
xaznx
Sep 16, 2002 08:46 PM
